Author Topic: I'm stupid.  (Read 3795 times)
Offline ola_martin
I'm stupid.
« on: November 26, 2010, 11:53:20 pm »
IT400C
Re: I'm stupid.
« Reply #1 on: November 27, 2010, 01:35:54 am »
hmmm, I thought it was supposed to just use a single rubber band that went from one clip to the other around the back of both fork tubes....
Offline ola_martin
Re: I'm stupid.
« Reply #2 on: November 27, 2010, 02:15:12 am »
There's two clips and two rubber-rings pictured in the parts catalogue..... ???
Re: I'm stupid.
« Reply #3 on: November 27, 2010, 09:56:59 am »
Originally it was 1 O-ring, but most of them had broken before the bikes left the dealers, the most stable way is to use 1 O-ring per clip like the photo. Take one to your local bearing shop and buy 50 of the suckers if you are going to race......change them every couple of months. I always have spare clips aswell in case you have an "off".
Offline Marc.com
Re: I'm stupid.
« Reply #4 on: November 27, 2010, 11:07:25 am »
Or spend $42 and fix the problem permanently.... Suzuki ones are the best of the lot
http://www.vintage-suzuki.com/products000029r_hardware.htm
Re: I'm stupid.
« Reply #5 on: November 28, 2010, 03:59:59 pm »
I thought that the earlier bikes had one band, and then as the forks grew in diameter (and further apart), they went to the two bands.
Normal O-rings are rubbish. The ones that you get with the VMX Plastics plates are nitrile(?) or something, that last a LOT longer.
Re: I'm stupid.
« Reply #6 on: November 28, 2010, 04:55:03 pm »
Why would you bother spending $42 on rubber bands and cobby bits of bent tin to hold your # plate on when you can do it and a hell of a lot more neatly and securely with these gizmos.
I've got them on all of my bikes and at $25 a pair they're not going to send you broke either.
Offline mick25
  • Hunter valley NSW
Re: I'm stupid.
« Reply #7 on: November 28, 2010, 06:32:01 pm »
Where did you get those rippers from mark,,do they make them in 36,38,43mm
Re: I'm stupid.
« Reply #8 on: November 28, 2010, 08:13:27 pm »
Your right Mark, those Suzuki ones are crappola....they scratch the shit out of the hard-chrome on the forks and the rubber bands are a shit to put on. I like those billet ones but have refranned from buying them....yet ;D....I have heeps of the Yammie ones as I sell Scotts VMX plastics products up here. I was thinking of designing a plastic version of the billet ones and getting them made. ;)
Re: I'm stupid.
« Reply #9 on: November 28, 2010, 08:46:39 pm »
Mick, there's a couple of different types often found on eBay but I get mine from a guy that advertises on the Vintage Flat Track website.....www.vft.org  http://www.vft.org/vftforsale2Products.html they are only available in 35mm or 38mm.
 I also found these slightly different and more expensive ones on eBay.
http://cgi.ebay.com/ebaymotors/HUSQVARNA-38-40mm-ALUMINUM-NUMBER-PLATE-MOUNTS-/280329003905?pt=Motorcycles_Parts_Accessories&hash=item4144e92381
http://cgi.ebay.com/ebaymotors/HUSQVARNA-35MM-ALUMINUM-NUMBER-PLATE-MOUNTS-TRICK-/280329001688?pt=Motorcycles_Parts_Accessories&hash=item4144e91ad8
http://www.billetinnovations.com/billet-number-plate-mounts.html][url]http://www.billetinnovations.com/billet-number-plate-mounts.html
[/url]
« Last Edit: November 28, 2010, 08:52:59 pm by firko »
Offline ola_martin
Re: I'm stupid.
« Reply #10 on: November 29, 2010, 10:00:38 pm »
My forks are 44 :-\
Re: I'm stupid.
« Reply #11 on: November 30, 2010, 05:33:50 pm »
Easy enough to get them bored out 1mm
