Author Topic: CR500 Intake Boot  (Read 3618 times)
rohan
CR500 Intake Boot
« on: November 26, 2010, 11:45:03 am »
A friend of mine is building a 85 CR500 and tells me air box to carby intake boots are impossible to get for that bike and no one has worked out what other models will fit. Is this correct? He is talking about making a mould and casting his own. I told him I would put a post on here to see what the gurus reckon.
Offline Mick22
Re: CR500 Intake Boot
« Reply #1 on: November 26, 2010, 01:09:10 pm »
If he is looking for a NOS part they may be hard to find but there are plenty of good second hand ones around
If he is looking for a new boot because the old boot has shrunk another fix is to make a spacer out of some 10-15mm ally plate that goes between the reed block and the cylinder. Just use a reed block gasket as a template and cut it out / drill etc. I have had a few CR's that have had this done and there is no noticable performance change. If you paint them black you can hardly notice they are there.
Or just buy one off US Ebay
« Reply #2 on: November 26, 2010, 01:12:33 pm »
are you talking Honda or Husky CR500?
if its Honda, i can confirm that CR250RG rear subframe and complete airbox will fit as that's whats on my 85' CR500RF.
Offline shorelinemc
  • life sucks&then you die
« Reply #3 on: November 26, 2010, 01:26:26 pm »
try yamaha of troy in the usa they are also honda dealers
rohan
« Reply #4 on: November 26, 2010, 02:02:04 pm »
Honda
rohan
« Reply #5 on: November 26, 2010, 04:51:03 pm »
I haven’t seen the bike so I don’t know if it raps around the shock. I guess I was hoping someone would say order one for a XXXX and trim it 10mm and it will fit perfectly...
Offline Mick22
« Reply #6 on: November 26, 2010, 04:58:24 pm »
What s wrong with buying the right one off Ebay and bolting it on?? there are plenty on there
And yes they wrap around the shock and are common to 85-89 CR500's and I think the 250's as well as Hoony said
« Last Edit: November 26, 2010, 05:02:02 pm by Mick22 »
rohan
« Reply #7 on: November 26, 2010, 05:08:12 pm »
Im not sure, maybe he is concerned they are old and brittle.
« Reply #8 on: November 26, 2010, 06:21:09 pm »
there was a post here some time back and the general concenus was that soaking old rubber in brake fluid softened it up again.
