Author Topic: KX 250 A5  (Read 2799 times)
Offline shorelinemc
  • life sucks&then you die
KX 250 A5
« on: November 23, 2010, 04:14:09 pm »
G`day chasing some bits for a kx 250 A5 need swingarm pivot bolt,swing arm bearings,spacers,seals thanks robin
Offline Trent Farlow
Re: KX 250 A5
« Reply #1 on: November 30, 2010, 08:42:46 pm »
You can still buy the seals and bearings from a bearing shop and a seal shop , the collars are best remanufactured , very easy job with a lathe.  let me know if you need help.
Offline shorelinemc
Re: KX 250 A5
« Reply #2 on: December 01, 2010, 12:22:20 pm »
no worries thanks
TM BILL
Re: KX 250 A5
« Reply #3 on: December 01, 2010, 01:09:21 pm »
Theres a pommy outfit making kits now i believe  ;)
Re: KX 250 A5
« Reply #4 on: December 01, 2010, 01:35:44 pm »
The bearings are usually common but the sleeves that sit inside the needle rollers should be hardened.
The sleeves are often common for different models which helps in finding a kit to suit.
Part # = 42036-1026
Part Description = SWING ARM SLEEVE
Model Count = 5
KX125-A4 78 125 KX125 MOTOCROSS
KLX250-A1 79 250 KLX250 OFF ROAD
KLX250-A2 80 250 KLX250 OFF ROAD
KX250-A4 78 250 KX250 MOTOCROSS
KX250-A5 79 250 KX250 MOTOCROSS
Offline grouty
Re: KX 250 A5
« Reply #5 on: December 02, 2010, 03:51:51 am »
It was me that was going to start making the kits.
I have been waiting a while to make sure the inserts that we manufactured worked. The original ones are related to cheese. The new ones are harder, but I want to make certain that they are not eating the swingarm pivot etc etc.
As Geoff said, they are not difficult to make.
I will keep you posted.
Thumpers Rule !
