Author Topic: Wheel offset?  (Read 4364 times)
Offline ola_martin
Wheel offset?
« on: November 17, 2010, 07:16:37 pm »
I'm having problems centering the frontwheel in my FOX forks. How much is it realistic to think i can move the rim over by adjusting the spokes ???
YZ -81 wheel.
Offline frostype400
Re: Wheel offset?
« Reply #1 on: November 17, 2010, 08:09:33 pm »
If your struggling and it is already laced just take it to the bike shop as long as you know the offset to true it I doubt they would charge you much.
1971 tm400 and PE's
Offline ola_martin
Re: Wheel offset?
« Reply #2 on: November 17, 2010, 08:30:02 pm »
I'm doing it myself, it's just that I've never tried to move it over before, and wonder how much I can expect.
Re: Wheel offset?
« Reply #3 on: November 17, 2010, 08:37:39 pm »
How much do you need/want to move it?
Re: Wheel offset?
« Reply #4 on: November 17, 2010, 08:41:27 pm »
You would be able to move it 5-10mm across.. is that enough?
Offline YZ250H
  • Back in QLD Baby !
Re: Wheel offset?
« Reply #5 on: November 17, 2010, 08:56:40 pm »
Why are fox forks any different (excuse my ignorance).  Are you sure you haven't left out a spacer or something ??
Offline ola_martin
Re: Wheel offset?
« Reply #6 on: November 17, 2010, 09:28:10 pm »
It's FOXforks for a Husqvarna, so I need room for a torquearm on the outside of the brakeplate, also the forkclamp is a lot wider so I can't get it far enough to the left.
I think I can make it work if I machine off 8mm from the brakeplate and get the rim offset about 5 mm to the side...
Do you think 5mm is ok, spokeangle etc?
Re: Wheel offset?
« Reply #7 on: November 17, 2010, 09:30:12 pm »
Yeah for 5mm you will be right, just try it and see, you will work it out.
Offline Colin Jay
Re: Wheel offset?
« Reply #8 on: November 17, 2010, 09:45:32 pm »
You will be suprised at how little adjustment of the spokes is require to move the rim across 5mm. I had to do similar when I fitted a Honda front wheel into the Ceriani forks that I run on one of My XT500 Yamaha's and it didn't take much to get that kind of offset.
CJ
Offline ola_martin
Re: Wheel offset?
« Reply #9 on: November 17, 2010, 10:01:32 pm »
Offline matcho mick
    • Moto Tumbi
Re: Wheel offset?
« Reply #10 on: November 18, 2010, 10:51:37 am »
not such a big deal with a 21" front wheel Wasp,spoke nipple hole angle realignment will be 5/8's of fuggall over 5mm rim movement  ;),only concideration would be if/maybe the threads might poke through on the side Ola's moving them across to,(anglegrinder ;D),handy tip Ola,release 2 turns before tightening 2 turns continously till rims moved to where you need it!, :P
