Author Topic: RM100/125 T sprocket cover plate thingy.  (Read 3400 times)
Offline rocketfrog
« on: November 17, 2010, 11:08:22 am »
Guys I am after a picture, diagram, tracing or original front sprocket/chain gaurd plate for the RM100/125 T.
I plan to copy one since they dont seem to be available any longer, and I cannot image that it would be too difficult to copy if I had an inkling of what it really looks like.
Perhaps someone who has one would be kind enough to trace one out on a sheet of paper and pencil in some dimensions for thickness.
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: RM100/125 T sprocket cover plate thingy.
« Reply #1 on: November 17, 2010, 05:47:39 pm »
Do you mean the half-moon thingy that sits over the chain, behind the front sprocket cover?
27641-41500  is the same thing as the PE175C/N which is definately out there...
Luke
« Reply #2 on: November 17, 2010, 06:56:54 pm »
Mr Rocket  :)  Pm me your Fax # and I will trace mine ( being chain guide / case saver ) and send it Thru thursday arvo.
Stewart
Offline rocketfrog
« Reply #3 on: November 18, 2010, 12:17:20 pm »
Yes fellas that half moon plate is the thingy I refer to. If its out there, I have not seen it. But then again, I tend to run hot and cold with chasing up obscure bits. Thanks for your offer Stewart, I will take you up on that. Check your PM's for my FAX details.
Cheers Jason
Offline rocketfrog
« Reply #4 on: November 19, 2010, 12:38:21 pm »
Thanks Stewart,
I recieved that fax of the Chain Protector Plate. I will have a crack at making one tonight if I can find a piece of scrap around @2.25mm (ish) thick.
Cheers Jason
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #5 on: November 21, 2010, 09:32:55 pm »
Ban BLACK rims NOW
