Author Topic: relocating the CDI  (Read 3664 times)
Offline jimson
  • Sanctuary point N.S.W
relocating the CDI
« on: January 18, 2008, 08:55:22 pm »
G'day viewers I want to relocate the cdi on a bike I'm building will the heat affect its use. At the momment its under the seat. I was thinking of putting it under the tank but that would mean its closer to the motor.jimson
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: relocating the CDI
« Reply #1 on: January 18, 2008, 08:59:50 pm »
heaps of bikes run the cdi under the tank as std,
as long as it's not directly on the exhaust, it should be good.
commonse the distance, as in, if it looks ok it should be.
"flat bickie"
Offline jimson
« Reply #2 on: January 18, 2008, 09:16:58 pm »
Thanks Vandy just wanted to be sure.jimson
« Reply #3 on: January 20, 2008, 10:06:58 pm »
Could you make it fit behind the front number plate ?
