Author Topic: -81/-82 Trick parts  (Read 10463 times)
Offline ola_martin
-81/-82 Trick parts
« on: November 12, 2010, 10:47:54 pm »
Hello.
I'm planning to build a special-looking CR430-82.
I have a set of Husky-ProCircuit sidepanels and rearfender with numberplates, and a 43mm KYB fork wich I plan to use. I've seen pics of a US huskyteam using this back in the day.
Then I've seen a boostbottle conversion buildt into the tank I want to try to make.
But I wonder what more period modifications that could be added to the bike, not much to find.
So please put up pics of cool parts and modifications used on -81/82 Huskys! :)
Also if anyone have pics of good looking paint/design to give it that special look.
Re: -81/-82 Trick parts
« Reply #1 on: November 13, 2010, 12:52:33 am »
I believe some places like www.husqvarna-parts.com has some replica Procircuit bits like brake pedals.
« Last Edit: November 13, 2010, 12:54:29 am by LWC82PE »
Offline ola_martin
« Reply #2 on: November 13, 2010, 02:22:58 am »
Thanks, I have that sidepanels and rearfender. It also have a boostbottle.... Anyone got more??  :)
Offline PEZBerq
  • Brisbane
« Reply #3 on: November 13, 2010, 10:22:46 am »
I wonder if there were any trick swing arms available. Cant say I recall any but someone must have made them surely ??? ??? ???. Sun rims were probably another mod - get away from 17 inch rear which Husky did it in 83 so maybe people were doing it earlier. Post a photo of your beast - before and after  :) :) Good luck ;D
« Last Edit: November 13, 2010, 10:25:49 am by LWC82PE »
Offline oldmxracer
« Reply #5 on: November 13, 2010, 10:44:31 am »
I think Thor (?) had a swingarm. If money is no problem I would contact Karl Landrus.
http://klpracing.com/
Offline ola_martin
« Reply #6 on: November 15, 2010, 07:50:02 pm »
I think a Maico 490 swing would almost fit, and then there's several alu. types to choose from. But I have two other expensive builds going on, so I can't spend so much on this bike...
I was thinking of putting on a Maico490 stock steel swing, to get that banana look...?
Offline Brian Watson
  • First Penton in OZ
« Reply #7 on: November 16, 2010, 10:39:37 am »
The Mossbarger reed block is a good mod....at odd times they come up on Ebay...you can still buy them new ....later ones had a neck for the connection to the boost bottle...You have to move the airbox back a little to fit it in...slightly deeper than the standard HVA reed assy...and IF...you could find an Asch pipe..well.... :-*
Offline Stevo17
« Reply #8 on: November 16, 2010, 02:19:15 pm »
Try these guys for some nice parts
www.huskyjunk.com
I used some of their bits on my 81 430CR
« Reply #9 on: November 16, 2010, 05:04:24 pm »
I think they still make them or can make them. i was reading a husky club newsletter and Mossbarger were advertising the reed valves in there a few years ago so they must still have all the patterns and tooling for the Husky valves. Worth emailing them anyway.
http://mossbargerracing.com/index1.htm
« Reply #10 on: November 16, 2010, 06:48:06 pm »
Yes the Huskyjunk website has Mossbarger reed blocks listed for sale.
I put one on my '83 430 years ago and it was the single best improvement i made to that bike, well worth it.
« Reply #11 on: November 16, 2010, 07:03:06 pm »
An 81 KTM item is a bolt in no mods at all
Offline ola_martin
« Reply #12 on: November 16, 2010, 07:39:08 pm »
;D ;D ;D
Offline Michel Dufayard
« Reply #13 on: October 24, 2015, 07:47:18 am »
The 470 procircuit KIT for husqvarna 430 cr is featured in the Motocross action of june 1982.
Has someone got it ?
« Reply #14 on: October 24, 2015, 08:35:00 am »
hey Ola, have you seen Big K's trick 430? Its a very nicely set up bike
