Author Topic: Yamaha YZ125K piston marked S is this a std piston  (Read 2382 times)
Offline oldyzman
  • 250 two stroke!
« on: November 11, 2010, 09:37:10 pm »
Gday,
I have purchased a Barrel and piston from US, they cannot measure the bore but did say that the piston was marked with a S, i am thinking this means std size (56mm). i want to confirm this so i can order a 1st oversize piston kit and get that on the way too. ANy thoughts
OLDYZMAN
Re: Yamaha YZ125K piston marked S is this a std piston
« Reply #1 on: November 11, 2010, 10:21:29 pm »
BRETT
looked on the usa parts site and they only show std pistons do they have chrome/plated bores
10    24X-11630-00-00 PISTON KIT STD (STD)   1
        39W-11630-00-00 PISTON KIT STD (STD)   1
11     24X-11631-00-95 PISTON STD (24X-11631-00-93)   1
         39W-11631-01-94 PISTON STD (39W-11631-00-95)   1
12        5X4-11611-02-00 RING, PISTON   1
13        137-11633-00-00 PIN, PISTON   1
14       93450-17129-00 CIRCLIP
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: November 11, 2010, 11:28:05 pm »
Thanks for your help Jim, the cyl i broke has cast iron  bore there seems to be some oversize 24x... pistons available, maybe just wait for the cyl to arrive. I just seem to recall seeinf an S marked on top of a std piston maybe off my 2002YZ
Cheers Brett, have a good weekend...
« Last Edit: November 11, 2010, 11:37:09 pm by oldyzman »
« Reply #3 on: November 23, 2010, 05:23:38 pm »
measure it
Offline oldyzman
  • 250 two stroke!
« Reply #4 on: November 24, 2010, 10:54:11 pm »
Freaky, the cylinder and piston was on the way from US. I wanted to pre empt size and order a piston in advance so i could get it all at nearly the same time. The dood selling it could not measure it. Any way its here now and is std...
Cheers Brett
