Author Topic: speedo mystery  (Read 4964 times)
Offline suzuki 400
speedo mystery
« on: November 10, 2010, 04:25:47 pm »
On my travels i have come across as suzuki speedo brown face in km looks like a pe speedo but no trip and less than 1 k on it boxed part number 34110-25027 cn any one share some light on this ?regards Rod
Offline frostype400
Re: speedo mystery
« Reply #1 on: November 10, 2010, 04:57:42 pm »
what speed does it go to though the PE's were always 160km and had a trip knob I am guessing Ts perhaps.
1971 tm400 and PE's
Offline suzuki 400
Re: speedo mystery
« Reply #2 on: November 10, 2010, 05:05:58 pm »
numbers end at 120 but indicates past that ,never seen a brown face on a ts its outer nz and its bloody cold here can,t wait to head back for warmer weather but fantastic trail rides organised here ,trail bikes are looked upon as great way to raise money for different charitys and for the farmers back pocket so everyone is happy, been out to the halcombe vinduro awesome
DR
Re: speedo mystery
« Reply #3 on: November 10, 2010, 05:10:15 pm »
76/77ish TS/TF models had brown faces on the gauges ;)
Re: speedo mystery
« Reply #4 on: November 10, 2010, 05:11:14 pm »
Photo will help big time showing case etc. Also is it a Nippon seiki or Nippon Denso? I would say its late 70's TF or TS at a guess without seeing it.
Also SP370 has brown face. I have some 76 TS250/400 speedos and they are pretty much the same as PE but black face and better internals.
« Last Edit: November 10, 2010, 05:13:31 pm by LWC82PE »
trailietrash
Re: speedo mystery
« Reply #5 on: November 10, 2010, 05:22:41 pm »
I have two 1976 TS125 ND speedo's both have black faces, both have trip meter and read up to 140 km/H. diameter at base is 90mm and lens dia is 75mm. Face says 1400REV=1KM
photo.....
« Last Edit: November 10, 2010, 05:49:54 pm by trailietrash »
Offline suzuki 400
Re: speedo mystery
« Reply #6 on: November 10, 2010, 05:59:22 pm »
Nippon Seiki every thing is the same as a pe just no trip meter and knob and tops out at 120 km/h still  if it will work on the pe thats where it will go ,by the comments id say its a ts/tf it also has green paint sealer under side id not seen before
Re: speedo mystery
« Reply #7 on: November 10, 2010, 06:07:48 pm »
Didnt you sell a proper PE speedo on ebay a while ago? Strange you cant reset the trip meter knob, but that tells me it was left off as a budget thing (cheaper) and that further strengthens the idea its off a cheaper trail type model. If i find some time i will try and research the part number (gotta try find some TF parts books). Quick google search wouldnt bring up anything for that number which indicates its probably specific to NZ/Australian markets, most likely small TS or TF 100/125/185cc. if we can work out what its off, we will then know the tyre size and can look up the gearing in the hub to know if it will read correctly on a 21 x300 tyre and the with the PE's hub gearing. It could also be off a small under 250cc road bike.
« Last Edit: November 10, 2010, 06:11:17 pm by LWC82PE »
trailietrash
Re: speedo mystery
« Reply #8 on: November 10, 2010, 06:20:01 pm »
I have a Yamaha speedo that is a Nippon Seiki that has no trip meter and tops out at 120 kph, lens is 52mm dia main body is 54mm. but again it has a black face with white lettering.
My TS125 parts book covers the K model through to the B and that part number is not listed it is not off something like a T125 stinger?
« Last Edit: November 10, 2010, 06:25:50 pm by trailietrash »
Offline suzuki 400
Re: speedo mystery
« Reply #9 on: November 10, 2010, 06:27:11 pm »
yes i did sell one but have another and this was to cheap to say no and i only need one for the one registered bike ,it also financed a new muffler for the rm465 and we paid in part for a holiday for the family to see there grandmother
Re: speedo mystery
« Reply #10 on: November 10, 2010, 06:49:54 pm »
Must of been an expensive speedo then :o
Offline frostype400
Re: speedo mystery
« Reply #11 on: November 10, 2010, 06:58:43 pm »
yeah what is the going rate now $300-$400 ???
1971 tm400 and PE's
Re: speedo mystery
« Reply #12 on: November 10, 2010, 07:03:14 pm »
Why are you asking, you have helped set the going rate recently ;D :D
Offline frostype400
Re: speedo mystery
« Reply #13 on: November 10, 2010, 07:11:54 pm »
I would like more I only have two of them and 6 pe's. ::)
1971 tm400 and PE's
DR
Re: speedo mystery
« Reply #14 on: November 10, 2010, 07:44:03 pm »
Leith I have the TC and TF parts books and it's not either of those. That's what made me think possibly RL especially as it's old style, only goes to 120kph, no neutral or indicator idiot lights, no trip meter and no parts listing that matches. Kinda like the optional TS kits parts, they exited but very few parts books after the early 70's show them or the corresponding part numbers.
