Author Topic: 1981 front number plates for honda  (Read 1475 times)
Offline martian170
« on: November 10, 2010, 02:00:04 am »
Hi Guys
I have both the 1981 honda cr250 and cr125 the 125 has an oval sloped front number plate is the 250 plate the same or i am led to think its a rectangle
either way i require one for the 250 be it oval or rectangle
Offline EVO_MX
Re: 1981 front number plates for honda
« Reply #1 on: November 12, 2010, 02:16:22 pm »
The original front number plate was  Rectangular with a vent at the bottom.
 You can replace the number plate with a modern 82 or newer model
if you put 84 or newer triple clamps on your motorcycle..
On the 250..
125 would require a 83 CR 125 number plate if you dont want to modify the triple clamps.
