Clubroom
Bike Talk
1038 Amal Carb
Topic: 1038 Amal Carb (Read 4626 times)
steve234
1038 Amal Carb
November 03, 2010, 11:06:15 am »
Can anyone assist with identifying a 1038 Amal carb needle. It has a 0.A stamped on it, and my bully parts book numbers it as a 29.15-006/0, I gather the 0 at the end relates to the 0 stamped on the needle but whats the .A all about?
Steve
Bultaco M106 Astro
LWC82PE
Superstar
Re: 1038 Amal Carb
November 03, 2010, 01:30:00 pm »
What type or carby is is it? have you got a photo?
Monoblocs 375, 376, 386 ? or concentric 600 or 900?
these letters indicate what carby needles are for the monoblocs
B - 375
C-376
D - 389
i will have to look up what A is but cant do it till tonight. Im guessing you have a concentric though.
steve234
Re: 1038 Amal Carb
November 03, 2010, 01:44:48 pm »
Its a 38mm concentric similar to the 900 series. So far i've found out the 0.A needle is for the #104 pursang, which ran a 36mm carb. So i'll try an 0 if I can get one and see how it goes.
Bultaco M106 Astro
matcho mick
Re: 1038 Amal Carb
November 03, 2010, 02:29:40 pm »
34,36,38's are 1000 series concentrics, 2" flange centre,thinking i used O needle for methanol in my 38,most (all)1000 series are two stroke carbs,
steve234
Re: 1038 Amal Carb
November 03, 2010, 03:23:21 pm »
1000 series it must be, carb has 1038 stamped on it.
Thanks Mick!
Bultaco M106 Astro
Clubroom
Bike Talk
1038 Amal Carb
