Author Topic: Flat slide Ei 38 carby on CR250 1983  (Read 1619 times)
Offline oldyzman
  • 250 two stroke!
« on: October 26, 2010, 08:26:37 pm »
Can someone advise what carby is std on this bike. and what the specs are for it hast anEi on it...Brett
Re: Flat slide Ei 38 carby on CR250 1983
« Reply #1 on: October 26, 2010, 08:32:14 pm »
The standard carby was a 36mm roundslide Keihin, probably better than the EI
Offline oldyzman
  • 250 two stroke!
« Reply #2 on: October 26, 2010, 09:10:02 pm »
Thanks for the advice Johnny, i started the bike after i cleaned it out it sounded quite good. That Ei has no pilot jet all rather simple. I have a mikuni sitting there of a yz250 - wonder how that would go on the CR as i have plenty of jets etc to set it up...
Cheers Brett
« Reply #3 on: October 26, 2010, 09:38:24 pm »
The mikuni would be ok if it's in good condition. To jet the EI you wind the needle up or down or use a different taper needle, very basic.
