Author Topic: pe 400 specs???  (Read 8270 times)
Offline PE MAN
pe 400 specs???
« on: October 22, 2010, 10:51:03 am »
does anyone know what power the pe 400 motor had... closest number i can find was from the rm 400c which had 43hp...
1980 SUZUKI RM50
1980 SUZUKI PE400
Re: pe 400 specs???
« Reply #1 on: October 22, 2010, 11:33:01 am »
According to the VMX article issue 21 -  37.6 hp at 7000rpm which is less than what the PE250Z brochure says (38.5hp at 8000rpm & 36.0 Nm torque at 6500 rpm)
1.5 HP down on RM4000 between 3000-4500 rpm. Beyond that the PE400 ruled the roost, gaining an extra 3.5hp more than RM400 after 7500rpm
1981 400X brochure says 31.0 KW (41.5hp) at 7000rpm. Max torque 43.0 Nm (4.41 kg.m, 31.9 lbs.ft)at 6000rpm
1982 400z has same power ratings and torque ratings.
In the end i think the brochures probably exagerate a bit. if you want a definitive answer get yours dyno tested, otherwise just ride it and enjoy it.
All this info comes from my info which is also availble on Lukes Skydrive for all to see so you must not have looked there.
« Last Edit: October 22, 2010, 11:37:39 am by LWC82PE »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: pe 400 specs???
« Reply #2 on: October 22, 2010, 05:03:12 pm »
You could peruse the zillions of PE things that are all here:
http://cid-407d7ef0965d3991.office.live.com/browse.aspx/Pure%20Enduro
