Marque Remarks
Yamaha
dt 360
Topic: dt 360 (Read 2195 times)
ludo
Novice
dt 360
October 17, 2010, 03:38:42 pm »
I HAVE A DT 360 THAT KEEPS POPPING THE CRANKSHAFT SEAL ON CLUTCH SIDE COULD THIS BE WORNE PISTON AND RINGS BUILDING UP PRESURE. YOUR HELP WOULD BE APRRECIATED.DAVE.
zorroz
A-Grade
Re: dt 360
October 17, 2010, 08:43:23 pm »
I've had this problem before with yammies. There is a Loctite retaining compound that will stop the seal from popping out just go to your local bearing shop they should point you in the right direction.
micks
A-Grade
Re: dt 360
October 18, 2010, 10:49:32 am »
from memory there is a retainer that bolts on the case to stop the seal from blowning out.
Marque Remarks
Yamaha
dt 360
