Author Topic: RM125 A con rod ? Where to get one ? ANSWERED  (Read 5006 times)
Offline Husabergpete
« on: October 16, 2010, 10:50:43 am »
Gents could someone point me in the right direction to get a Rod for my RM125A project.
Pete
0407915014
« Last Edit: December 04, 2010, 08:01:43 am by Husabergpete »
Re: RM125 A con rod ? Where to get one ?
« Reply #1 on: October 16, 2010, 12:07:16 pm »
Ebay in the States....only place you will get one and there usually on all the time.
« Reply #2 on: October 16, 2010, 01:21:12 pm »
Thanks Dave
Offline suzuki27
« Reply #3 on: October 16, 2010, 05:06:40 pm »
I believe you can upgrade them to the larger little end bearing size of the latter years. 125B,C,. N etc.
Anyone on here done it?. I can find out off a mate if need be.
« Reply #4 on: October 16, 2010, 06:38:30 pm »
B & C rods can be used, but they have a smaller top end bearing. You will have to find 56mm piston to suit. An Elsinore piston can be used but has a higher compression ratio, so you'll have to adjust it unless you want to use high octane fuel.
« Reply #6 on: October 16, 2010, 09:55:04 pm »
43,
Can,t get into this link right now but I found 2 rods on Ebay this arvo using the part number. Waiting for a price for shipping. But looks like I will be able to get something soon. The later model info is really helpfull too. Ta Pete.
Ah just got into that one now. And that is another one again. The rods I found had no pin or bearing.  Thanks for the help.
« Last Edit: October 16, 2010, 10:00:32 pm by Husabergpete »
suzuki43
« Reply #7 on: October 17, 2010, 06:35:46 am »
Pete
Let me know if you need hand with shipping.
Craig
TM BILL
« Reply #8 on: October 22, 2010, 08:14:51 am »
Use TS 125 rod kits and pistons , just turn the piston skirt down a bit.
All available from Suzuki or aftermarket , pistons available up to 2mm OS
I think the  RM uses a better quality BE bearing but the TS ones work fine and give long service .
« Reply #9 on: December 04, 2010, 07:57:52 am »
Boys the result was I got a NOS rod from US Ebay for $40 usd. Bought the bearing and pin from Extreme Powersports in the USA. Shame they didn't send the full order I paid for. The rod is in and the motor sitting on the bench.
This RM125A has been a ground up rebuild, powder coated, NOS consumables, 2nd O/S sukuki piston, respoked etc etc and the list goes on.
I will be selling it once built and hoping someone in a clulb like Heaven will take it for a junior or similar.
If you know anyone who might be interested I can send photos etc of the build up and finished bike (soon)
[email protected]
All the best Pete
Offline ricakk
Re: RM125 A con rod ? Where to get one ? ANSWERED
« Reply #10 on: December 04, 2010, 09:13:21 am »
Hello Pete  did you use any of those piston and ring, were they even 125 A stuff
« Reply #11 on: December 05, 2010, 08:27:58 am »
Rick,
Yeah kind of. The head-barrell and half of the pistons and rings worked out to be for a C - 1978 model. The Suzuki piston ended up being an A an in the rebuild. Took some working out. The gudgen pin on the A is different to the later model ones as is the bore size from Standard. It is easy to mix pistons etc up.  I'll give you a call soon.
ta Pete
