Author Topic: TM 250 no oil feed ?  (Read 11699 times)
« on: January 12, 2008, 11:31:27 pm »
I gotta stop buying bikes without looking closer.
I just bought a bike off Ajay or cozzie or mad max or someone and it doesnt have the oil feeds ? i understood TM250 couldnt have the Oil line removed without Dire consiquenses unless the main bearing we drilled to ?
Can any one tell me how i can check to see this has been done ?
Ajay or cozzie did you do this or know if it was done at all or checked ?
Where can i get all the oil bits if i need to refit them to this bike before i run it > i was under the inpression the motor was rebuild so im not wanting to start the bike unless i know it has the mod done, or i search, buy and refit an oil system
HELP !!!!!
Re: TM 250 no oil feed ?
« Reply #1 on: January 13, 2008, 09:40:49 am »
you gotta pull the motor apart ot see if there is a shield over the left main bearing. if its removed then you can use pre mix.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #2 on: January 13, 2008, 09:45:27 am »
And ensure an oil relief hole has been drilled between the main bearing and oil-seal on the magneto side. Otherwise when the crankcase is presurised on the down stroke fuel/oil won't be forced through the bearing and up into the transfer port.
Ban BLACK rims NOW
« Reply #3 on: January 13, 2008, 10:00:07 am »
Ajay or cozzie any ideas befor ei have to pull this thing apart ?
Cycle can that been seen from outside or is that an inside only view, im not big on pulling cases apart ..............
Offline jimson
  • Sanctuary point N.S.W
« Reply #4 on: January 13, 2008, 10:01:36 am »
Freaky you must buy a lot of bikes to forget who you get them from ;D jimson
« Reply #5 on: January 13, 2008, 10:54:55 am »
NA both of them had it, i got it from cozzie, who got it from Ajay, what i want to know is did they do it or know if its been done, i dont split cases and kinda aint inclined to pay for it to be done just to check why the oils been removed and has it beed modded to infact run un-feed, i figure asking is easier, before it blows its brains out first time its ridden.
Wish life was easy somtimes
Doc
« Reply #6 on: January 13, 2008, 12:54:27 pm »
Go to the Yahoo Suzuki forum..there's just been a big debate on this. The slinger plate must be removed but the hole above the left main may not be needed. I need to pop the top off my RL as they are premix from the factory. I read quite few cases of plate removed, lines blocked off and no other mod and these bikes ran on indefinately. I'm a big believer in leaving the oil pumps but there really is no reasoning behind this only for the fact after having RM's mostly, oil tanks and pumps are bit of a novelty  :P
http://autos.groups.yahoo.com/group/tmsuzuki/
« Reply #7 on: January 13, 2008, 01:17:00 pm »
Freaky,
Removing the pump is a snack but as everyone else mentioned you must split the cases to do it properly.Simply a matter of blocking the feeds, drilling out the oil hole to 3mm and cutting the slinger down to expose the bearing.
CG FWIW air/fuel never has nor never will be 'forced' through the transfer ports, and especialy not by decending pistons, old wives tale No.456. ;)
Offline Noel
« Reply #8 on: January 13, 2008, 08:27:17 pm »
Freaky.
is this the ex Barry Senn  (NZ) bike,
 if it is I feel sure it was done properly
Noel
« Reply #9 on: January 14, 2008, 12:00:52 am »
I have no idea.  im waiting for Ajay or cozzie to join us, i got it from them, and im not sure they no where it came from ? i just need to know if i have to pull this bastard apart before i can use the motor, of if its been done and if so how can i tell if they are unsure or no one knows .
Offline Noel
« Reply #10 on: January 14, 2008, 08:54:47 am »
 A picture would help Identify the bike,
Noel
Doc
« Reply #11 on: January 14, 2008, 01:01:44 pm »
Pretty sure I remember seeing this bike before either of the previous owners purchased it. It was a few years back and it was in QLD. I'd say you are going to have to take a look inside Freaky. Something I normally do with any secondhand bike/motor I buy just to satisfy my curiosity as to bore size, top and bottom end condition and I also look for signs of any previous drama and tell tale scaring. If it's all good then I bolt her back together and ride it. Even if the previous owner says he did this and that I still check cause I hate not knowing for sure when it comes to something that can go bang ;)
Phil
« Reply #12 on: January 14, 2008, 03:21:30 pm »
Wasn't the ex Barry Senn bike Cozzie sold to Ajay an RH75? What are we dealing with here?
If you remove the oil slinger from a TM250 crank it should be sufficient. I've never had to resort to drilling holes before but I see the engineering behind the idea. Seeing you don't like splitting engines pay a competent mechanic to have a look for you freak.
« Reply #13 on: January 14, 2008, 04:39:52 pm »
On my TM/TS VMX project bike the oil slinger was removed and no other mods were needed. It runs fine.
I can't believe you don't remember who you bought the bike off Freaky. Is it a TM or is it something else? I don't recall Ajay with a TM 250.
Why don't you like splitting cases? For a bloke with a collection like yours I would have thought you'd be a regular genius on 2 strokes.
Doc
« Reply #14 on: January 14, 2008, 05:45:32 pm »
 :D this is really turning into a mystery until AJay/Cozzie can shed some light on the matter. The TM250 I remember seeing had sideplates made from sheetmetal and sprayed green. The bike was very patina at the time but I've no idea what she could look like now..This is going back a few years and the reason I remember this particular TM250 is because the price was right and I was contemplating a move on it myself. Alas, I could not afford to go there and left well and good enough alone. I was sure AJay swooped on it, would this be the TM in question??
