Author Topic: WANTED YAMAHA DT1/RT1 TYPE REAR BRAKE PEDAL & ARM TYPE  (Read 1923 times)
« on: October 12, 2010, 01:52:59 pm »
hi
need a rear brake for my flat track bike.i need a brake rhs pedal that is in 2 parts.the rod an arm need to be inside back of frame so the kick starter will still work.
most guys in the usa use starters for these bikes and biuld disc brakes on the rhs cant use the kicker then
yamaha rt1 2 3 or dt1 2 3 type is what i am after
thanks
jim
Re: WANTED YAMAHA DT1/RT1 TYPE REAR BRAKE PEDAL & ARM TYPE
« Reply #1 on: October 12, 2010, 02:05:27 pm »
Jim....I can give you a stock DT1 brake pedal if that'll do you...just come and get it mate.
« Reply #2 on: October 12, 2010, 03:39:49 pm »
mark
is it both parts because the other part isthe 1 i need as i have to cut and shut the pedal
jim
« Reply #3 on: October 12, 2010, 08:38:24 pm »
Some old shitters of the required 360 arm/pedal went to Nathan S's from my place ;) Tim754
« Last Edit: October 15, 2010, 02:01:09 pm by Tim754 »
« Reply #4 on: October 12, 2010, 09:53:54 pm »
Definitely got the shaft with the arm, not so sure about the pedal itself.
« Reply #5 on: October 12, 2010, 10:23:17 pm »
thats good as firko definitly has the arm. this is good.now i need a small peice of 10mm alloy plate
jim
« Reply #6 on: October 12, 2010, 10:28:35 pm »
I can help you there as well Jim. ;)
« Reply #7 on: October 13, 2010, 12:27:31 pm »
heaps of pedals on ebay
