Author Topic: tm 125 parts  (Read 2431 times)
Offline dodgee
tm 125 parts
« on: October 08, 2010, 03:36:51 pm »
nos rear guard tm125  $100
tm125 barrell . 5 os with gem reed block and new rm125s piston and rings $300
rm 125 inner clutch hub  nos  can be fitted to tm125  $100
ph  0411 101524
wayne
Offline brent j
Re: tm 125 parts
« Reply #1 on: October 08, 2010, 05:06:32 pm »
Wayne, is the rear guard the inner or the outer?
Offline dodgee
Re: tm 125 parts
« Reply #2 on: October 08, 2010, 07:39:29 pm »
outer rear guard
Re: tm 125 parts
« Reply #3 on: October 08, 2010, 08:29:07 pm »
Brent,  ......125 and 250 are the same  ;)  as I have a 125 on my 250     NOS  yellow
Offline brent j
Re: tm 125 parts
« Reply #4 on: October 08, 2010, 09:12:14 pm »
Thanks guys,
I'm after an inner for my TM185 project.
Where did you get yours from Stu?
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: tm 125 parts
« Reply #5 on: October 09, 2010, 09:11:12 am »
Thanks guys,
Just get the RM125M inner from DC plastics, no need to bother with the two-piece inner the TM's use.
Ban BLACK rims NOW
Stewy138
Re: tm 125 parts
« Reply #6 on: October 11, 2010, 11:39:28 pm »
Hey Wayne,
Youve got all the good stuff for sure  :)
What is the inside diameter of the Gem reed block (if not sold already) ?  I would want to run that with a 32mm carb.  Can you still get reed petals for it ?
The clutch hub has straight cut gears ? (better than the helical gears in the standard TM engine).
Thanks,
Stewy.
