Author Topic: CZ 250 shifter lever  (Read 2282 times)
shakeyCZ
« on: October 08, 2010, 10:25:27 am »
Hi dose any body no what shifter lever will fit on a cz ? ??? ???
Offline Bamford#69
Re: CZ 250 shifter lever
« Reply #1 on: October 08, 2010, 12:24:10 pm »
Hi,
Early Yamaha (fine splines), common as in most accessory shops
Try to find a CZ shift lever, they are very soft and can be restraightened easily, even when back to the footpeg!,a bit like Maguras, they also are good protection to reduce damage to the shift shaft .
« Reply #2 on: October 08, 2010, 04:24:50 pm »
I'm running a pattern folding tip lever for a yamaha like Jikov recommends, not sure what model its from but it was quite long & I shortened it to get the length right. Other option would have been to get a alloy 1 from czstuff when you got the shaft from him
