Author Topic: Mystery 2 stroke engine  (Read 12378 times)
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: Mystery 2 stroke engine
« Reply #15 on: September 26, 2010, 07:19:57 pm »
then i will work out what to do with it.
slider frame?  ;)
« Reply #16 on: September 26, 2010, 07:57:52 pm »
It would have been good if i had a chassis for it, at least one of the swinging arm models because then you could build a decent pre 60 or pre 65 bike. Only spare frames i have are some Adler frames but they are plunger rear end, plus this motor is a lot taller than an Adler so probably wouldnt fit anyway. Its probably going to be hard to find stuff for this motor. I havent even worked out the capacity yet. If i cant work out what it is by this saturday then i will take it to the swapmeet on the 3rd, not sure what its worth couple hundred maybe?
Its all very restorable, i was amazed to see no broken fins on the head.
