Author Topic: 1990 Ktm 500 - What is the correct Ignition time spec BTDC ?  (Read 5297 times)
Offline jurado
« on: September 24, 2010, 04:25:43 pm »
I have just restored a 1990 ktm 500, two-stroke, and I am not sure about what ignition time spec should run with. I know the ignition time spec is very important for engine performance, and would like to ensure I am using the correct one. I low time spec would result is significant power output. I also know a high time spec would damage the engine (and your foot when kick-starting!).
I have a manual for a 1990 ktm 350 cc and it says ignition time spec should be 2.1 mm Before Top Dead Center (B.T.D.C.). I own some other 350 cc bikes (360 h7 Montesas, with similar 350 cc engines and compression ratios), and they properly run with 3.0 mm BTDC time spec. So I do not understand why the ktm 350 time spec is lower.
Assuming the 2.1 mm spec is correct for the ktm 350, should not the ktm 500 run with a bigger spec, let´s say 2.5 mm, or 3.0 mm ?. A bigger spec would seem logical to me, since there is more volume of compressed mixture to ignite since sparks till piston reaches its TDC
Your views appreciated.
Regards,,,,, Jurado.
Code: [Select]
http://i56.tinypic.com/125i0xu.jpg
Offline jurado
Re: 1990 Ktm 500 - What is the correct Ignition time spec BTDC ?
« Reply #1 on: September 24, 2010, 04:27:38 pm »
now with picture.
« Reply #2 on: September 24, 2010, 07:45:37 pm »
You can find a workshop manual here
http://www.repairmanual.com/category/ktm-atvs-and-motorcycles/
should have timing spec in there
Offline jurado
« Reply #3 on: September 28, 2010, 10:46:03 pm »
Thanks. Indeed, the manual talks about an spec of 2.1-2.2 mm BTDC for the 500 cc engine. However the manual also says that this spec is for the MOTOPLAT ignition system, but for a  SEM K11 ignition system should be 1.45-1.55 mm BTDC, which does not make sense to me.
I have read that the correct spec for the 500 cc engine is 2.5-2.9 mm BTDC. I would expect that when increasing the spec you loos some power at low rpm, but gain at medium-high regime. Tou might get some kickbacks if spec is too high. I wonder whether someone has experience in all this.
Thanks,,, Jurado.
