Author Topic: GMC pipes  (Read 12823 times)
Offline shortshifter
  • Sunshine Coast QLD
GMC pipes
« on: September 21, 2010, 07:02:05 pm »
JUst got my GMC pipe in the mail today,raced home and took the old standard 260 pipe off.Test fiT the GMC pipe after putting on silastic gasket DOH!Doesn't fit exactly,grind off a bit of the front engine plate for the front section of header pipe to clear bolt up start up  into paddock WOW!!!If you don't have one of these you should!!!apart from looking ace they bloody work.thanks Mr Morris.
Re: GMC pipes
« Reply #1 on: September 21, 2010, 10:15:36 pm »
Glad you like it.
Some one else has said it's a bit tight on the fins too.
How much did you need to trim off?
Offline NR555
Re: GMC pipes
« Reply #2 on: September 21, 2010, 10:54:26 pm »
Are these pipes a copy of standard, or are the specifications for each model calculated by a tuner or tuning software?
Re: GMC pipes
« Reply #3 on: September 22, 2010, 08:35:38 am »
Geoff I had to grind off 2/3 mm off the leading top edge of the engine plate.the header pipe is still touching and I might need to take a little more off as the spiggott is still proud of the barrell not flush but there are no leaks.No problems with the finning though.You know better than me there isn't a lot of room to work with between the front frame downpipe,fins and exhaust port.
TT
Re: GMC pipes
« Reply #4 on: September 22, 2010, 09:42:01 am »
It might upset GMC to remind him of this, but imagine how many hours go into the process of building a pipe from scratch. The research, testing and then the actual building.
When you think of all that, they're bloody cheap too!  ;D
Offline vmx42
Re: GMC pipes
« Reply #5 on: September 22, 2010, 10:57:21 am »
I don't think you will upset him Tony.
Now that GMC is a hugely successful multinational conglomerate, Geoff has his minions do all the hard graft. He is just the figurehead, sitting in his ivory tower having a manicure, surveying his domain and remembering how it 'used to be'.
Ah… the memories!!!!!  ;)
Re: GMC pipes
« Reply #6 on: September 22, 2010, 11:01:33 am »
Different models are built to different specs. based on design, space, experiance and feedback.
The side pipes as mentioned above are a compromise pipe, as are all sidepipes.
There just isn't the room to build the size and length needed when attached to the side of the bike
My CZ side pipes have headers that are a very close copy of the originals and are interchangeable with originals.
The chambers are a slightly different spec and don't have the huge dents in them that the originals have and this helps them perform better than the originals. Also come with built in mufflers.
360 at front, 250 at rear
360 header
Heatshields are a laser cut copy of the original 360 heatshield
The post 70 models are completely different to stock.
They are a one piece design with built in muffler, I get good feedback for these models.
Re: GMC pipes
« Reply #7 on: September 22, 2010, 11:15:47 am »
Ha, I tried experimental cloning to enable my world domination plans to be successful.
Now that he’s 15 it just wants to sit on his arse much the same way I did.
Offline vmx42
Re: GMC pipes
« Reply #8 on: September 22, 2010, 11:18:00 am »
so the cloning was 100% successful then?
Offline NR555
Re: GMC pipes
« Reply #9 on: September 22, 2010, 11:21:38 am »
I know how many hours go into it!  We had a pipe built recently for the EMC.  The bike was gone for a week.
GMC seems popular, so I was curious as to what went into these pipes.  They definitely look the biz.
Offline POM
Re: GMC pipes
« Reply #10 on: September 22, 2010, 11:27:34 am »
Those pipes look real neat gmc!...I reckon it would make an interesting thread on what goes into making one.....how you make/roll/cut the cones etc......
shoey
Re: GMC pipes
« Reply #11 on: September 22, 2010, 11:33:03 am »
Great Aussie made products
here's our might 430 with the GMC pipe.
Fitted striaght up to the bike and coupled perfectly to the standard husky silencer
The Man's a true metal artist
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: GMC pipes
« Reply #12 on: September 22, 2010, 11:48:01 am »
did he also supply the pine cone for that pic Shoey?
"flat bickie"
shoey
Re: GMC pipes
« Reply #13 on: September 22, 2010, 11:55:54 am »
Nice pick-up Vandy.
Pine cone is from Pete's kit bag.
Doggy Digger
Re: GMC pipes
« Reply #14 on: September 22, 2010, 12:37:59 pm »
Technically speaking, the porcupine-pattern pine cone should only be used for Falta replicas, or FMF-kitted 125 Elsinores.
For the majority of makes with standard finning like the 430 above, please use a pineapple or hand grenade ... something like that.
« Last Edit: September 22, 2010, 12:43:47 pm by Doggy Digger »
