Clubroom
Tech Talk
Building a trailer
Topic: Building a trailer (Read 1969 times)
jimson
Sanctuary point N.S.W
Building a trailer
September 17, 2010, 11:03:21 pm »
G'day viewers I'm building a trailer I was thinking if I have a cut out section in the front the bikes front wheel will slide in to it like a push bike stand at school.So then if I put a tie down around the back of the front wheel that would stop the downward pressure on the forks and still hold the bike upright what do you blokes think
jimson
Mick22
A-Grade
Re: Building a trailer
September 18, 2010, 07:52:07 am »
I think the important bit is to hold the back of the front wheel as well so that the steering is locked out. Otherwise even when they are tied in the bike tries to walk around. I have seen a few attempts at this and they haven't worked too well unless the wheel is really well held.
These things work well but I think they are around $70 so it starts to add up when you're buying 3 or 4
http://www.birdman.net.au/pitposse-ramps.html
ant73
September 26, 2010, 04:02:30 pm »
I have put some bits of wood in the bottom of my trailer for the bikes wheels to sit in, this stops the bike from sliding to the side, I still use tie downs with a fork brace or an old oil bottle. Works well for me
ANT
BAHNZY
September 26, 2010, 04:35:30 pm »
From my expierence.
Tie the bike (chassis) down at the back and the front.
The oscillating movement of the rear shock doesn't help the seal head and shaft in the long term.
Rod (BAHNZY) Bahn
jimson
Reply #4 on:
October 16, 2010, 11:17:52 pm »
This is it so far its going to be bloody heavy
jimson
Clubroom
Tech Talk
Building a trailer
