Author Topic: KX500 clutch plates  (Read 5625 times)
Doc
KX500 clutch plates
« on: January 09, 2008, 08:22:32 am »
Hi, does anyone know if the '85 KX500 non powervalve model clutch frictions swap with the later model part?
Offline holeshot buddy
  • sunshine coast qld
Re: KX500 clutch plates
« Reply #1 on: January 13, 2008, 09:04:17 pm »
hey doc i have an 85 500 kx and also spare motor i know the clutches and gearboxs are the same
83 84 85 ,not sure about later clutch plates have had later model 500s but always order right clutch plate for model i know the part numbers are differant i will try and find out ,just a note you should be able to get 85 clutch plates 8)
it ran last time i started it ;D
follow me to first turn
« Reply #2 on: January 13, 2008, 11:43:47 pm »
Doc you can get any friction plates rebonded with a carbon kevlar mix for approx $16ea.
Doc
« Reply #3 on: January 14, 2008, 06:38:18 am »
Thanks holeshot buddy, I believe the owner of this bike was going to give you a call about this. Yeah we can still get the plates but we spotted the full kits in the US at about $70Au delivered but only to suit '87 onwards  :-\
Offline Maicojames
« Reply #4 on: January 15, 2008, 09:00:11 am »
http://www.barnettclutches.com/products/clutch_plates_springs.aspx?type=clutches_other&clutch_make=Kawasaki&clutch_cc=500
Looks like Barnett has the earlier ones as well-see above link, though you may find nos Kawasaki plates. I ran Barnett plate in my 92 KX250, worked great, they seem to work fine except in Maicos(where i always run stock plates).
Lozza, got a link to the place who rebonds them?
Thanks, James
Life is suddenly very Monaro
Doc
« Reply #5 on: January 16, 2008, 12:24:15 pm »
Thanks James, we could probably hunt up a Barnett kit..I used Barnett plates in my RM's years ago and they were okay..nothing special but they worked.
This is the problem..a quote from a local kwak dealer for genuine '85 KX plates was around $250. Accessory plates were priced at $220. I then mentioned to my friend ( incidently his name is DJ but not the DJ on this forum) that I had seen plate kits on Ebay US delivered to my door for about $75. BIG DIFFERENCE!! This is why I am wondering if the later model plates will fit as there is a stack of them available where-as very little for the '85 specifically. Differing part numbers with no substitutions tells me they are a special deal that doesn't interchange but I was just wondering if someone had actually tried. It's all about cost as the parts aren't rare but genuine are expensive.
« Last Edit: January 16, 2008, 12:26:43 pm by Doc »
« Reply #6 on: January 16, 2008, 09:16:09 pm »
Check to see if MCS do them at you local outlet  ;)
« Reply #7 on: January 16, 2008, 11:41:34 pm »
doc i can probably get goodrich plates or prox plates they would be heaps cheaper ring me at work i will
find out :D gotta keep those kx500s going at all costs ;D
Doc
« Reply #9 on: January 17, 2008, 04:21:08 pm »
mmmm..still a little pricey thanks James..I was thinking more along the lines of something like this http://cgi.ebay.com/ebaymotors/NOS-Barnett-Kawasaki-Clutch-Kit-KX250-KX420-KX500_W0QQcmdZViewItemQQcategoryZ35581QQihZ010QQitemZ200097216626QQrdZ1QQsspagenameZWD1VQQtrksidZp1638Q2em118Q2el1247  but I still don't know the difference between the models..if I knew they definately don't fit then I'd have to look at the more expensive.
Holeshot Buddy, I do believe you know the bike and owner (DJ) last I spoke to him he was going to phone you directly..thanks!
