Author Topic: 1983 RM500  (Read 7936 times)
Offline BAHNZY
1983 RM500
« on: September 12, 2010, 08:52:14 pm »
$20,000 spent, asking $7000
Is a lot of coin for a RM500, be interesting to see if it gets a bid over the starting price of $6000
Rod (BAHNZY) Bahn
Offline dalesween
Re: 1983 RM500
« Reply #1 on: September 12, 2010, 08:53:38 pm »
Where's the link?
cheers Dale.
suzuki43
Re: 1983 RM500
« Reply #2 on: September 12, 2010, 08:56:07 pm »
http://cgi.ebay.com.au/SUZUKI-RM500-1983-/280561099039?pt=AU_Motorcycles&hash=item4152bea11f
How could you spend $20K on that and still have dirty old maier plastic on it?
He must have rebuilt the engine out of gold.....
TELL HIM HE"S DREAMING!!!!
Offline BAHNZY
Re: 1983 RM500
« Reply #3 on: September 12, 2010, 09:01:14 pm »
Oops, forgot the link. Thanks 43
Rod (BAHNZY) Bahn
Offline dalesween
Re: 1983 RM500
« Reply #4 on: September 12, 2010, 09:04:55 pm »
20G should include a pretty nice sticker kit!
cheers Dale.
Offline zorroz
Re: 1983 RM500
« Reply #5 on: September 12, 2010, 10:37:41 pm »
D&G exhaust - Dolce Gabbana? Thats why he spent 20g on it!
Re: 1983 RM500
« Reply #6 on: September 12, 2010, 11:05:46 pm »
Must've drank 15g worth of piss while building it.. still got rusty old bolts all over it.
Offline TeeBone
Re: 1983 RM500
« Reply #7 on: September 13, 2010, 02:32:53 am »
"2hrs riding time since rebuild"...you'd have thought he'd at least paint the motor "properly" in amongst that 20G spend!
Offline seego
Re: 1983 RM500
« Reply #8 on: September 13, 2010, 02:53:08 pm »
the bike is not a complete 1983 model the front brakes and forks are 1984 models
Offline BAHNZY
Re: 1983 RM500
« Reply #9 on: September 13, 2010, 10:37:02 pm »
And now this one turns up, be interesting to see where the reserve is sitting at.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=300467487403&ssPageName=ADME:B:SS:AU:1123
Rod (BAHNZY) Bahn
Re: 1983 RM500
« Reply #10 on: September 14, 2010, 12:19:35 am »
Bahnzy (and I am sure Craig will chip in as well) - this one is close to home so I am interested - however I hear they are an absolute nightmare for parts (even Suzuki themselves say so).  What are the risks with these?
Rossco
suzuki43
Re: 1983 RM500
« Reply #11 on: September 14, 2010, 05:21:16 am »
Rossco my old mate,the achilles heel of RM500's is the unavailability of rods mate.Everything else is out there if you look hard enough.
« Last Edit: September 15, 2010, 03:17:26 pm by suzuki43 »
Offline BAHNZY
Re: 1983 RM500
« Reply #12 on: September 16, 2010, 12:59:30 pm »
Rossco,
Engine aside, the chassis shares a lot with the 250 of the same vintage so it helps a little.
- Swing arm, head stem, wheel bearings are readily available.
- Swing arms have a tendency to crack at the boss where the swing arm bearings are installed.
- The bearings in links from the rocker to the swing arm can be a bit exy.
- If you have access to a lathe, you can replicate the factory items with a handful of spherical eyes and a piece of 20mm alloy bar.
- The rear shock is generally rooted and whilst they can be overhauled, typically I have found that its akin to Flogging A Dead Horse.
- Ohlins & WP shocks can be sourced without too much problem, it's just the $'s that you have to be aware of.
- ALWAYS check the frame around the foot peg and lower frame area. Rusting from the inside out, cracked foot peg mounts etc are the norm unfortunately.
- Plastics, no issue. Seat Cover No issue
- Cables and most consumables are also available.
- The rear shock flaps and rubber gaskets in and around that area are NLA. The do appear on flea-bay from time to time but are very expensive.
And the engine.
- Beware of loose engine mounts and the subsequent damage that this can cause. Have seen some very bad example’s of this.
- Conrods are as rare as rocking horse shit, pistons not so bad.
- Have seen a handful of 465’s and one 500 where the barrel had cracked around the mounting boss where it bolts to the cases,
- Engine internals are always on USA flea-bay, and generally not that expensive.
- DG do a complete exhaust (pipe and muffler) although most people that I have spoken to that have fitted them prefer the power delivery of the standard combination.
- Gasket Sets and seals etc are generally no issue.
- Kick-starters are always flogged out and very expensive to replace.
- The flat slide carbie will be toasted. Don’t mess with it, pitch it for a new unit.
And the worst part (in my mind) is the previous modifications. Many complained about the power delivery of the bike and a lot of so called “experts” messed with the bike in an effort to fix it. Horrible porting work, compression & carburettor changes etc are not unusual to find and in most cases can’t be reversed cheaply.
Rod (BAHNZY) Bahn
Re: 1983 RM500
« Reply #13 on: September 16, 2010, 03:21:38 pm »
thanks gents (and that includes you Craig!) - unfortunately at work at the moment so can't get to have a look at it - will keep and eye on the auction though and see what happens.
suzuki43
Re: 1983 RM500
« Reply #14 on: September 16, 2010, 03:29:26 pm »
