Author Topic: PE400 original LH grip  (Read 5422 times)
rohan
« on: September 09, 2010, 07:00:58 pm »
I purchased an "original" LH grip from suzuki Aus for a 1980 pe400 and they have sent me a similar grip but not original (part no 57211-27C00 . I have since been informed that is all suz Aus can supply as they dont carry the original gear and would have to get it from the states.
I found the part number i need from the schematics on bike bandit which is part# 1100342 (3322-001) however to get it from Bike Bandit in the states they have a minimum postage of $111.00...
Can anyone inform me where I can get the part I need in Aus or elsewhere but at a fair postage rate.
TT
Re: PE400 original LH grip
« Reply #1 on: September 09, 2010, 07:07:07 pm »
Try Ray at Suzi Parts.
He really knows his stuff.
[email protected]
www.suziparts.com.au
« Reply #2 on: September 09, 2010, 07:29:46 pm »
actual part # is     57211- 40200         and superceeded to   57211-27COO ( which means it is from another stock bin )
Ray might have the part ......but you will be parting with some serious dollars also  ;)
« Reply #3 on: September 09, 2010, 07:52:03 pm »
Ha, the original left grip is impossible to find. If you find one then let me know! The grip that superceeds it is very very similar and they are still the basic same waffle pattern, and if your not doing a concourse restoration then this would be fine for most people. The original NLA grips are not very good anyway, the ribs are not very high or cushioning. The new grips are better. From memory the newer superceded grip is whats fitted to some newer DR/RM models.
rohan
« Reply #4 on: September 09, 2010, 07:57:37 pm »
The problem is I put in a big order to bike bandit about a month ago and got a new throttle assembly that came with an original brand new grip but didnt include the left side. I know purchase the LH side from Aus suz and they dont match...
« Reply #5 on: September 09, 2010, 08:18:18 pm »
Yeah i had the same prob. What you have to do is remove the grip from the throttle tube. its glued on but yes it can be done. Then you need to buy the matching newer grip.......
Now the only thing is that i reckon when ever you buy a RH grip off one of these models that it probably comes on the tube. i dont know if suzuki sell all the right grips on the tubes for all these models? I think it may be hard to get one off the tube with out damaging it to put it on the PE tube. I really think you might have to get a set of $20 aftermarket OEM replica grips. The common XR pattern is very similar to the new suzuki pattern, still the basic old school waffel. if you dont mind aftermarket grips with brand names on them then the Scott Hurricane grips are a good pattern and quite popular. Also Oury are very good. You should find allsorts on ebay or oterwise just go to your local bike shop, they can help with grips. As others have said, even if you do find a NOS left grip, its probably gonna be dry/hard/perished or very expensive and for the price of that one grip you could get 5 or more pairs of aftermarket grips. The grip would be too expensive and if you havent got barkbusters on, the first time you tip the bike over the end of the grip will get damaged and there goes your mega dollar left grip! I its a $20 aftermarket set, thats not going to matter so much.
By the way, ive been trying to get the original grip left grip for 7 years for a resto and i would not be surprised if it was discontinued long before 2003.
Part # = 57211-27C00
Part Description = GRIP,LEFT
Model Count = 168
DR-Z400EY 2000 400 DR-Z400E DUAL PURPOSE
DR-Z400SY 2000 400 DR-Z400S DUAL PURPOSE
DR-Z400Y 2000 400 DR-Z400 DUAL PURPOSE
DR125ES 1995 125 DR125E DUAL PURPOSE
DR125ET 1996 125 DR125E DUAL PURPOSE
DR125SER 1994 125 DR125SE DUAL PURPOSE
DR200SET 1996 200 DR200SE DUAL PURPOSE
DR200SEV 1997 200 DR200SE DUAL PURPOSE
DR200SEW 1998 200 DR200SE DUAL PURPOSE
DR200SEX 1999 200 DR200SE DUAL PURPOSE
DR200SEY 2000 200 DR200SE DUAL PURPOSE
DR250L 1990 250 DR250 DUAL PURPOSE
DR250M 1991 250 DR250 DUAL PURPOSE
DR250N 1992 250 DR250 DUAL PURPOSE
DR250P 1993 250 DR250 DUAL PURPOSE
DR250SEP 1993 250 DR250SE DUAL PURPOSE
DR250SER 1994 250 DR250SE DUAL PURPOSE
DR250SES 1985 250 DR250SE DUAL PURPOSE
DR250SL 1990 250 DR250S DUAL PURPOSE
DR250SM 1991 250 DR250S DUAL PURPOSE
DR250SN 1992 250 DR250S DUAL PURPOSE
DR350L 1990 350 DR350 DUAL PURPOSE
DR350M 1991 350 DR350 DUAL PURPOSE
DR350N 1992 350 DR350 DUAL PURPOSE
DR350P 1993 350 DR350 DUAL PURPOSE
DR350R 1994 350 DR350 DUAL PURPOSE
DR350SER 1994 350 DR350SE DUAL PURPOSE
DR350SES 1995 350 DR350SE DUAL PURPOSE
DR350SET 1996 350 DR350SE DUAL PURPOSE
DR350SEV 1997 350 DR350SE DUAL PURPOSE
DR350SEW 1998 350 DR350SE DUAL PURPOSE
DR350SEX 1999 350 DR350SE DUAL PURPOSE
DR350S 1995 350 DR350 DUAL PURPOSE
DR350SL 1990 350 DR350S DUAL PURPOSE
DR350SM 1991 350 DR350S DUAL PURPOSE
DR350SN 1992 350 DR350S DUAL PURPOSE
DR350SP 1993 350 DR350S DUAL PURPOSE
DR350T 1996 350 DR350 DUAL PURPOSE
DR350V 1997 350 DR350 DUAL PURPOSE
DR350W 1998 350 DR350 DUAL PURPOSE
DR350X 1999 350 DR350 DUAL PURPOSE
DR650SEW 1998 650 DR650SE DUAL PURPOSE
PE175C 1978 172 PE175 DUAL PURPOSE
PE175D 1983 172 PE175 DUAL PURPOSE
PE175E 1984 172 PE175 DUAL PURPOSE
PE175N 1979 172 PE175 DUAL PURPOSE
PE175T 1980 172 PE175 DUAL PURPOSE
PE175X 1981 172 PE175 DUAL PURPOSE
PE175Z 1982 172 PE175 DUAL PURPOSE
PE250B 1977 246 PE250 DUAL PURPOSE
PE250C 1978 246 PE250 DUAL PURPOSE
PE250N 1979 246 PE250 DUAL PURPOSE
PE250T 1980 246 PE250 DUAL PURPOSE
PE250X 1981 246 PE250 DUAL PURPOSE
PE400T 1980 397 PE400 DUAL PURPOSE
PE400X 1981 397 PE400 DUAL PURPOSE
RL250L 1974 246 RL250 EXACTA TRIALS
RL250M 1975 246 RL250 EXACTA TRIALS
RMX250K 1989 249 RMX250 OFF ROAD
RMX250L 1990 249 RMX250 OFF ROAD
RMX250M 1991 249 RMX250 OFF ROAD
RMX250N 1992 249 RMX250 OFF ROAD
RMX250P 1993 249 RMX250 OFF ROAD
RMX250R 1994 249 RMX250 OFF ROAD
RMX250S 1995 249 RMX250 OFF ROAD
RMX250T 1996 249 RMX250 OFF ROAD
RMX250V 1997 249 RMX250 OFF ROAD
RMX250W 1998 249 RMX250 OFF ROAD
RM100A 1976 98 RM100 OFF ROAD
RM100B 1977 98 RM100 OFF ROAD
RM100C 1978 98 RM100 OFF ROAD
RM100N 1979 98 RM100 OFF ROAD
RM100T 1980 98 RM100 OFF ROAD
RM100X 1981 98 RM100 OFF ROAD
RM125A 1976 123 RM125 OFF ROAD
RM125B 1977 123 RM125 OFF ROAD
RM125C 1978 123 RM125 OFF ROAD
RM125D 1983 124 RM125 OFF ROAD
RM125E 1984 124 RM125 OFF ROAD
RM125F 1985 124 RM125 OFF ROAD
RM125G 1986 124 RM125 OFF ROAD
RM125H 1987 124 RM125 OFF ROAD
RM125J 1988 124 RM125 OFF ROAD
RM125K 1989 124 RM125 OFF ROAD
RM125L 1990 124 RM125 OFF ROAD
RM125M 1991 124 RM125 OFF ROAD
RM125N 1992 124 RM125 OFF ROAD
RM125P 1993 124 RM125 OFF ROAD
RM125R 1994 124 RM125 OFF ROAD
RM125S 1995 124 RM125 OFF ROAD
RM125T 1996 124 RM125 OFF ROAD
RM125V 1997 124 RM125 OFF ROAD
RM125W 1998 124 RM125 OFF ROAD
RM125X 1999 124 RM125 OFF ROAD
RM125Z 1982 124 RM125 OFF ROAD
RM250A 1976 246 RM250 OFF ROAD
RM250B 1977 246 RM250 OFF ROAD
RM250C 1978 246 RM250 OFF ROAD
RM250C2 1978 1/2 246 RM250 OFF ROAD
RM250D 1983 246 RM250 OFF ROAD
RM250E 1984 246 RM250 OFF ROAD
RM250F 1985 246 RM250 OFF ROAD
RM250G 1986 246 RM250 OFF ROAD
RM250H 1987 246 RM250 OFF ROAD
RM250J 1988 246 RM250 OFF ROAD
RM250K 1989 246 RM250 OFF ROAD
RM250L 1990 246 RM250 OFF ROAD
RM250M 1991 249 RM250 OFF ROAD
RM250N 1992 249 RM250 OFF ROAD
RM250P 1993 249 RM250 OFF ROAD
RM250R 1994 249 RM250 OFF ROAD
RM250S 1995 249 RM250 OFF ROAD
RM250T 1996 249 RM250 OFF ROAD
RM250V 1997 249 RM250 OFF ROAD
RM250W 1998 249 RM250 OFF ROAD
RM250X 1999 249 RM250 OFF ROAD
RM250Z 1982 246 RM250 OFF ROAD
RM370A 1976 372 RM370 OFF ROAD
RM370B 1977 372 RM370 OFF ROAD
RM400C 1978 402 RM400 OFF ROAD
RM400N 1979 417 RM400 OFF ROAD
RM400T 1980 417 RM400 OFF ROAD
RM465X 1981 465 RM465 OFF ROAD
RM465Z 1982 465 RM465 OFF ROAD
RM500D 1983 492 RM500 OFF ROAD
RM500E 1984 492 RM500 OFF ROAD
RM80B 1977 79 RM80 OFF ROAD
RM80C 1978 79 RM80 OFF ROAD
RM80D 1983 79 RM80 OFF ROAD
RM80E 1984 79 RM80 OFF ROAD
RM80F 1985 79 RM80 OFF ROAD
RM80G 1986 79 RM80 OFF ROAD
RM80H 1987 79 RM80 OFF ROAD
RM80J 1988 79 RM80 OFF ROAD
RM80K 1989 79 RM80 OFF ROAD
RM80L 1990 79 RM80 OFF ROAD
RM80M 1991 79 RM80 OFF ROAD
RM80N 1992 79 RM80 OFF ROAD
RM80P 1993 79 RM80 OFF ROAD
RM80R 1994 79 RM80 OFF ROAD
RM80S 1995 79 RM80 OFF ROAD
RM80T 1996 82 RM80 OFF ROAD
RM80V 1997 82 RM80 OFF ROAD
RM80W 1998 84 RM80 OFF ROAD
RM80X 1999 82 RM80 OFF ROAD
RMYP UK UK RMYP UK
RM80Z 1982 79 RM80 OFF ROAD
RS175T 1996 175 RS175 DUAL SPORT
RS175X 1981 175 RS175 DUAL SPORT
RS175Z 1982 175 RS175 DUAL SPORT
RS250T 1980 250 RS250 DUAL SPORT
RS250X 1981 250 RS250 DUAL SPORT
SP600F 1985 600 SP600 DUAL SPORT
TM100L 1974 98 TM100 CONTENDER OFF ROAD
TM100M 1975 98 TM100 CONTENDER OFF ROAD
TM125L 1974 123 TM125 CHALLENGER OFF ROAD
TM250J 1972 246 TM250 CHAMPION OFF ROAD
TM250K 1973 246 TM250 CHAMPION OFF ROAD
TM250L 1974 246 TM250 CHAMPION OFF ROAD
TM250M 1975 246 TM250 CHAMPION OFF ROAD
TM400J 1972 396 TM400 CYCLONE OFF ROAD
TM400K 1973 396 TM400 CYCLONE OFF ROAD
TM400L 1974 396 TM400 CYCLONE OFF ROAD
TM400M 1975 396 TM400 CYCLONE OFF ROAD
TM400R 1971 396 TM400 CYCLONE OFF ROAD
TM75A 1976 72 TM75 MINI CROSS OFF ROAD
TM75L 1974 72 TM75 MINI CROSS OFF ROAD
TM75M 1975 72 TM75 MINI CROSS OFF ROAD
« Last Edit: September 09, 2010, 08:21:00 pm by LWC82PE »
« Reply #6 on: September 09, 2010, 09:16:20 pm »
sounds like bike bandit should change their name to postage bandit,$110 for 1 grip now thats what i called tearing off their customers ears
Offline frostype400
« Reply #7 on: September 09, 2010, 09:19:32 pm »
I will only run original grips on one of my PE's you can get much better feeling grips than stockers anyway some Scotts or alike that still have a vintage look.
http://www.motoduro.co.uk/include/suzuki15.php
My PE400x has a quick pull throttle and scott grips that don't look out of place if you keep them black. :)
1971 tm400 and PE's
Offline frostype400
« Reply #8 on: September 09, 2010, 09:21:28 pm »
Yeah but watch some of the US guys for postage don't just buy something and assume they will look after without being qouted postage.
1971 tm400 and PE's
« Reply #9 on: September 09, 2010, 09:25:32 pm »
yeah you always get the post rates first to save a nasty shock and a massive dent to the wallet ;)  :o ;) ;D
Offline Maicojames
« Reply #10 on: September 13, 2010, 05:49:13 am »
Again, if you need something like that...well there is just no way in hell it can really cost $111.00 to ship a grip. I can help if you can not get it in oz. I have offered this several times, but was only taken up on it once-by Glen, btw, you were so generous, the wife and I love the sweatshirts still.
  I realize that I am in Texas, so big parts should go through the west coast of US. All I am saying is, I would be honored to help out any VMX brothers-and do not expect to stick you with bullshit cost to handle, hell send me a cool Oz vmx kind of decal and I am floored. We are not all attending tea parties and butt forking our underage cousins while watching nascrap. I have failed to locate some nos items requested, and reget that, but am always willing to send along from one of those sellers who is not only sickly nationalisitc, but fails to remember how Australia has fought side by side with the US in just about every major conflict since.. well you get the point.
Be well, James
« Last Edit: September 13, 2010, 05:52:03 am by Maicojames »
Life is suddenly very Monaro
« Reply #11 on: September 13, 2010, 07:04:06 am »
James, thanks for your offer on USA postage. I will keep you in mind next time I have a small item needed om this of the ditch .
Cheers Stewart
rohan
« Reply #12 on: September 13, 2010, 06:56:52 pm »
James,
Thanks for the kind offer. With respect to the grip I took previous advice and got a complete aftermarket set.
I may have lived a sheltered life, but your the first American I have met in my 35 years that seems to be on the same wave length as us ozzies...
Offline frostype400
« Reply #13 on: September 13, 2010, 07:11:47 pm »
Good choice I took my 400T for a spin around the front yard this after noon after changing the air filter and plug it has original grips but they arent as comfortable as the newer scotts on my 400x. :)
1971 tm400 and PE's
monaro308
« Reply #14 on: September 14, 2010, 01:41:06 am »
Remember the old trick of putting a 2 cent piece in the end of the bar then the grip so when you drop the bike it wouldn't chew the end off the grip?  ;D
