Author Topic: CR 500 84 paint code  (Read 5843 times)
Offline Mick22
« on: September 02, 2010, 12:33:59 pm »
Does anyone have a pait code for the frame color on a CR500 84 model?
I used to have a list of the paint codes for CR's but can't find it
STW996
Re: CR 500 84 paint code
« Reply #1 on: September 03, 2010, 05:35:52 am »
84 Honda is R119 Flash Red
Offline Mick22
« Reply #2 on: September 03, 2010, 07:53:12 am »
Thanks STW, what I'm afetr is the paint code that corresponds to R119 Flash Red, there was a list going around a while back that had the standard Honda colors and a list of PPG colors that matched
STW996
« Reply #3 on: September 03, 2010, 03:50:00 pm »
Ok not sure but we do powdercoating and I have a good Dulux rep that might do some digging for me.
He is off for another week so when he is back I will put it to him.
Shane
Offline Boyracer
« Reply #4 on: September 07, 2010, 06:14:48 pm »
Two pack will chip up pretty quick, your better off with powder coating if you can get flash red.
Offline E74
« Reply #5 on: September 07, 2010, 07:23:33 pm »
I have had it formulated at my paint supplier, I just ring them for it and they make it up, give me a yell if you need some, and off course best results come from powder coating the frame first in a close enough colour, rub it back with 1200 wet and then give it one coat of 2k.
and yes make sure it is zinc coated first.. ;)
« Last Edit: September 19, 2010, 09:52:36 pm by E74 »
STW996
« Reply #6 on: September 08, 2010, 05:47:43 am »
Gee Darren as a person who powder coats I would not be doing that! unless it is a zinc based primer powder coat, like any other paint it is porous and needs a primer to seal it.
