Author Topic: RM 125 firing specs  (Read 2431 times)
Offline PCMAX
RM 125 firing specs
« on: August 29, 2010, 07:41:58 pm »
Does anyone know the specs for the ignition timing for a 1981 RM125? ie firing point in mm or degrees BTDC @xxxx RPM
Re: RM 125 firing specs
« Reply #1 on: August 29, 2010, 10:16:41 pm »
For a top end set up go 0.8-0.9 and for mx 1.2-5mm BTDC
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #2 on: August 30, 2010, 03:31:08 am »
or go by the book - 17  degrees BTDC.
What timing light have you got that runs to 10000? Mine shuts down WAY before that.
Luke
« Last Edit: August 30, 2010, 03:37:51 am by lukeb1961 »
Offline PCMAX
« Reply #3 on: August 30, 2010, 10:49:42 am »
Luke,
I only have a basic timing light though I do know of someone who has a very good one that might still operate at 10,000rpm. Will try to get it and see what mine is running at. For now I will set it at around about 1.2 mm as suggested by "Lozza"
Thanks for the replies
Peter
