Author Topic: Levers for Minis  (Read 4170 times)
Offline YZ250H
  • Back in QLD Baby !
Levers for Minis
« on: August 28, 2010, 05:42:42 pm »
Hi Guys,
Looking for some ideas here as the "standard" YZ50 levers are the same as a 125  :o.
Looking for something a little shorter and closer to the bars.  There are a few short ones on Ebay, but I can't find any that really fit the bill.  Maybe other brands have ones to suit smaller hands ??
Ideas ??
Re: Levers for Minis
« Reply #1 on: August 28, 2010, 05:53:01 pm »
What about just getting the YZ125 'shorty' levers? theres bound to be 100's on ebay. Or do you you still need shorter levers than the 'shorty' option? maybe consider some mountain bike levers or something and then just change the nipple size.
Offline YZ250H
« Reply #2 on: August 28, 2010, 05:55:49 pm »
Thanks Leith.  The perches are the same as 125.  All the ones on ebay I can see are for disc brake models.  I will have a look at the local bike shop to see what they have.  These minis are a bit different - you have to make them work for a much smaller rider (obvious I suppose  ::)  )
« Reply #3 on: August 28, 2010, 07:17:04 pm »
There should be shortys availble that cover all Yamaha drum brake models. Have a look here www.mcsonline.com.au to see what your local shop can get.
or go to www.denniskirk.com and search for these numbers
57-170 - alloy
57-171 - black
these are shorty lever sets for most drum yamahas 72-84
Offline YZ250H
« Reply #4 on: August 28, 2010, 07:33:56 pm »
Looking at KX 60.  They look to be far smaller and closer to the bars.  Wonder if a yammy cable fits a Kwaka lever?
« Reply #5 on: August 28, 2010, 07:55:22 pm »
Have you decided to go for something a bit more manageable than the 465?
Offline YZ250H
« Reply #6 on: August 29, 2010, 10:43:23 am »
Yeah, even the 80 is too muck for me  ;D ;D
Soooo  hairdo - does a yz cable fit a kx lever ??
« Reply #7 on: August 29, 2010, 02:45:58 pm »
General rule of thumb all Yamaha, suzuki, and kawasaki older drum brake/clutch levers are all basically interchangeable and fit each others perches. Its the Hondas that are different. Cable nipple size should be OK too.
Offline YZ250H
« Reply #8 on: August 29, 2010, 02:58:53 pm »
Excellent thanks Leith.
Levers and perches on ebay for $15  8)
« Reply #9 on: August 29, 2010, 03:58:40 pm »
I always remember seeing replacement magura levers advertised for original perches and they always had suz/kaw/yam, i probably have some here and i also have seen levers advertised as YSK so thats how i know. The exception to the rule is when theres brake  light switched in the front lever but for most of the old MX bikes without the switches they interchange fine apart from the honda levers.
Offline YZ250H
« Reply #10 on: August 29, 2010, 05:00:40 pm »
Thanks Leith.  The KX60 ones are in the bag.  They look smaller and are straight forward - very very similar to the YZ perches.  I'll see what happens when they get here.  Thanks for the help and advice.  Always appreciated.
