Author Topic: a suspension question  (Read 4102 times)
Doc
« on: January 06, 2008, 05:49:50 pm »
okay..if one has a pair of fork legs and they are longer then standard and poke thru the top clamp say an extra 40mm, is it okay so long as the actual travel remains within the rules? I assume it is okay but assuming has got me into strife before.
Re: a suspension question
« Reply #1 on: January 06, 2008, 10:12:51 pm »
the rules as i read them say period ( in the era time wise) and available pre whatever the cut off year is, and the actual travel available is as per rules AKA 7.1/2 inch they cold be off a bobtail chopper for all it matters and stick out 5ft so long as the travel is correct.
« Reply #2 on: January 06, 2008, 10:49:51 pm »
No worries as long as they're 7"
Doc
« Reply #3 on: January 06, 2008, 11:47:53 pm »
thanks..it'll save a lot of work if I can use as is.
YSS
« Reply #4 on: January 24, 2008, 11:09:47 pm »
And if those forks where available in that period
