Marketplace
Wanted
YZ 465 H SHOCK SPRING
Topic: YZ 465 H SHOCK SPRING (Read 2135 times)
over the bars
C-Grade
August 25, 2010, 07:03:33 pm »
Wanted, YZ 465 H shock spring. YZ 490 K fork tubes . YZ 465 G back wheel in usable condition. Cheers.
LWC82PE
Superstar
Re: YZ 465 H SHOCK SPRING
August 25, 2010, 07:35:02 pm »
I have got a used White Power shock spring off a 1982 YZ490 if its any use to you. (been painted yellow)
spring length – 285mm
Its in USA though, so you cant be in a rush to have it tomorrow
over the bars
C-Grade
August 25, 2010, 08:05:16 pm »
Thanks , but I need a progressive spring . Ive been told a 490 spring is a constant rate due to the linkage or rising rate suspension. Thanks again.
LWC82PE
Superstar
August 25, 2010, 08:18:08 pm »
yeah that one isnt progressive.
over the bars
C-Grade
Reply #4 on:
August 26, 2010, 04:53:54 pm »
Cheers, I will get in touch with you. Thanks again.
Marketplace
Wanted
