Author Topic: 360H7 for MX ??  (Read 3334 times)
Offline bultokid
360H7 for MX ??
« on: August 25, 2010, 12:46:16 am »
Hello to all, have enjoyed reading the bb for many years. I now have a VB360 and will soon have my ex-VB250. Had a VF414 at once---regret selling that one ! Have been on Husky last year and many years on Buls before that. My quest is to build a Monty for the AHRMA GP class. I would have better luck hitting the lotto than finding a VG model here in the states. From time to time a 360H7 pops up here so I got a wild hair. How would a H7 do at mx, once it's set-up for it ? I am thinking putting some larger forks on and such. How does a H7 motor compare to a VB ?  What are the chances of finding a VG tank ? Is the VE/VF/VG tank the same, just different color ? I appreciate all the advice I can get and enjoy the forum. Regards---Rhett
All Things 414
Re: 360H7 for MX ??
« Reply #1 on: August 25, 2010, 06:48:35 am »
Hi Rhett. I think a 360H7 would be pretty good for MX. The newer frame geometry of the H7 would have to be a bonus and they deffinatly have a better front brake than the 414's. You'd probably have to gear it down quite a bit (something I found with my 250 H7) and even then you'd probably never get it into top gear on an MX track (top gear is more like a road gear for between Enduro sections I believe). I think it'd be a nice torquey engine like the 414's as well. Chop the rear loop and you'd have an impressive looking bike even if you leave the H7 tank on it.
The VE tank is different in where it mounts but the VF and VG tanks are interchangable.
If you are able to get hold of a VG tank and chop the rear you should end up with something that looks a bit like this......
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: 360H7 for MX ??
« Reply #2 on: August 25, 2010, 08:14:02 am »
Rhett,
Here's a link to a conversion.  It's in Spanish, but with a lot of pictures.
http://www.tumotoverde.com/index.php?option=com_fireboard&Itemid=124&func=view&id=98488&catid=6
        Cheers, Jared
All Things 414
Re: 360H7 for MX ??
« Reply #3 on: August 25, 2010, 10:28:18 am »
Wow! Good link Jared. If you hit the translate button it's fairly easy to work out what he's on about. Pretty thorough. :)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: 360H7 for MX ??
« Reply #4 on: August 25, 2010, 10:41:31 am »
I live in Arizona.  Spanish is my second language! Hola... ;D
Offline hitatreeonce
  • rather be an old fart than a young dickhead
Re: 360H7 for MX ??
« Reply #5 on: August 25, 2010, 07:33:43 pm »
I've been racing a h6360 for 3 years and its ok first gears a little low and proberly some porting would bring it up to cappra specs but I have a bag of fun go for it!
Offline bultokid
Re: 360H7 for MX ??
« Reply #6 on: August 25, 2010, 09:22:11 pm »
Jared, many thanks for that killer link. My Spanish translation says ---- way beyond my skill level  ;D
