Author Topic: YZ125X / 125C Left CrankCase. & Cover. Will take whole motor..  (Read 3061 times)
Offline steveo247
gday,
I'm looking for an undamaged left hand crankcase for my 125X.
Mine has been smashed from a chain and i'm hoping to find another good one, and use my mangled one for the race bike.
Im also looking for the crankcase cover for that side. T
heres a few on ebay, but if i can not have to ship these out from america id be much happier!
The crankcases are the same on the 125C and X, and i think the A/B cases would fit too? (can someone help with that?)
I'll take a whole motor if i need too!
Contact me on here,
or email on [email protected]
thanks very much.
steve.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: YZ125X / 125C Left CrankCase. & Cover. Will take whole motor..
« Reply #1 on: August 19, 2010, 12:18:58 pm »
A/B will be different.
externally the magneto cover is different, internally i'm unsure.
i'm led to believe the TY175 is the same as the C/X but as usual, i've been wrong before.
« Last Edit: August 19, 2010, 02:27:36 pm by vandy010 »
"flat bickie"
« Reply #2 on: August 19, 2010, 01:54:11 pm »
what about the 76+ Dt 125 / 175 ?
Offline steveo247
« Reply #3 on: August 19, 2010, 02:10:32 pm »
Dad thought that too. I can only go off part numbers, and they are different?
« Reply #4 on: August 19, 2010, 03:33:05 pm »
Ok well thats all i have for you.........
« Reply #5 on: August 19, 2010, 04:42:57 pm »
YZ125C/X and probably TY175 are the same.
The other likely candidates (DT, earlier/later YZes etc) are all different, in one way or another (usually relating to the shift drum and/or the rods the shift forks slide along, at least).
I've got a spare YZ-C case, but will have to confirm condition before making any big promises.
May also have a spare ignition cover too.
Offline steveo247
« Reply #6 on: August 20, 2010, 09:33:39 pm »
looking forward to hearing your reply mate!
i think i have the cover sorted..
« Reply #7 on: August 20, 2010, 10:07:31 pm »
YES THEY ARE.
Here is a recent one I repaired
machined weldable piece.
welded, prior to invisible machining finish and dremal finish.
Run a twenty mm reamer through the finished repair, beautiful ;).
« Last Edit: August 20, 2010, 10:10:39 pm by MICK-DE »
Offline steveo247
« Reply #8 on: August 23, 2010, 07:59:05 am »
YES THEY ARE.
Thats a erally tidy repair mick-de!
If i cant find one, you'll have a PM !
