Author Topic: Welding Honda CR80 Cases  (Read 3762 times)
Mr Aussie
« on: August 14, 2010, 04:32:59 pm »
Does anyone know what honda made the crankcases out of
Are they a Standard Alloy or a Magnesium Alloy
I have a small crack i want to seal up and dont want to weld it if it is Magnesium
Offline caps 999
Re: Welding Honda CR80 Cases
« Reply #1 on: August 14, 2010, 07:29:24 pm »
center cases are alloy and most clutch covers on the 80 are alloy to i think its only the aircooled 80 that had a mag clutch cover
MUGEN power
« Reply #2 on: August 14, 2010, 09:41:27 pm »
I haven't known of any production center cases that were Mag.
« Reply #3 on: August 14, 2010, 09:52:12 pm »
And if any outer cases are magnesium, they often have it cast in 'magnesium' so you know. CR80 will be Alumimnium for sure.
Mr Aussie
« Reply #4 on: August 15, 2010, 07:12:02 am »
Thanks Guys
I will see if i can blow a hole in it with the TIG :o
« Reply #5 on: August 15, 2010, 08:55:17 am »
Make sure you put a piece of Stainless behind the hole to help.
Offline caps 999
« Reply #6 on: August 15, 2010, 09:23:49 am »
not all cases are marked magneisum leith the cr480 clutch cover its mag and not marked
MUGEN power
Mr Aussie
« Reply #7 on: August 15, 2010, 01:04:20 pm »
Yea these cases are quite thin compared to what i have welded in the past
Mr Aussie
« Reply #8 on: August 22, 2010, 06:14:59 pm »
Well i got the TIG warmed up today
Prepared the case
Pre-heated it
and welded it
Came up a treat
After grinding it back and finishing it off with a linisher and some emery tape
you would never know
It was a piece of cake
