Author Topic: Forks to suit RM125T  (Read 4370 times)
« on: August 14, 2010, 10:58:46 am »
What would my options be for Forks and triples? ie. still evo legal but maybe off a 250 or a later model 125?
Offline suzuki27
Re: Forks to suit RM125T
« Reply #1 on: August 16, 2010, 07:15:36 pm »
The forks off a 125X ,Z or D would be good. Still 38mm but don't rely on air to work properly.
« Reply #2 on: August 18, 2010, 09:40:54 am »
Are they the 'same' as any of the T model forks though? ie. would they still be evo legal?
Offline BAHNZY
« Reply #3 on: August 18, 2010, 12:36:12 pm »
If the donor bike is fitted with a;
DISC BRAKE
(or)
HAD A LINKAGE REAR SUSPENSION
(or)
WAS WATER COOLED
then the forks would not be EVO legal.
This is one of the reasons that the YZ465 fork/twin leading front end is so sought after.
It’s a big diameter fork that can be improved easily (springs, valving etc) and it has an awesome twin leading brake unit, and most importantly the donor bike was air-cooled, non linkage with drum brakes as original equipment.
Rod (BAHNZY) Bahn
Offline motomaniac
« Reply #4 on: August 18, 2010, 12:45:16 pm »
What s wrong with using 125T forks ? They were pretty good .
« Reply #5 on: August 18, 2010, 01:48:05 pm »
I should have mentioned I have a frame less forks/triples. Just wanted to check what my options were before I started looking
Offline Tex
« Reply #6 on: August 18, 2010, 03:08:40 pm »
I have forks & triple from RM125X/Z/D going cheap if you want 'em.
« Reply #7 on: August 18, 2010, 04:07:06 pm »
I may be interested, i'd need to find out how they differ from the T forks first though.
« Reply #8 on: August 20, 2010, 04:27:58 pm »
Does anyone know if the later 38mm 125 forks are the same as the earlier evo era 250 forks?
« Reply #9 on: August 20, 2010, 05:00:47 pm »
Rm 1979 > 1980  are the ones you want due to O/set
« Reply #10 on: August 21, 2010, 10:06:58 am »
are you talking about just the triples Stu, or is the whole setup different?
Got any spare sets? ;D
« Reply #11 on: August 21, 2010, 05:23:43 pm »
Not knowing what you have in mind  ???  Rm on a Pe will work fine and opposite...  longer forks has an effect on your handling  ;)  From memory Brent J has it all sussed out on a mix and matching triple's to obtain offset. Think there was a thread way back
Offline ty4
« Reply #12 on: August 22, 2010, 09:01:19 am »
i have a set of 125 T triples if that helps
tony
