Author Topic: Powernow carb mod  (Read 9416 times)
Offline vmxrider
Powernow carb mod
« on: August 12, 2010, 12:25:30 pm »
Just heard about this thing today, seems to have some merit in reducing 4 stroke cough off idle and some gian in low end on 2 strokes, looks easy enough to make one to try, but probably not era legal for VMX.
http://www.scaryfastracing.net/
Re: Powernow carb mod
« Reply #1 on: August 12, 2010, 12:39:53 pm »
Who's gunna know? ;D
(Lozza or someone else might like to tell us if the performance is as good as the promise  ;))
« Last Edit: August 12, 2010, 12:41:32 pm by mx250 »
« Reply #2 on: August 12, 2010, 12:54:26 pm »
BTW it looks like BS to me but I would love someone to buy it and prove me wrong. 8)
Why BS? Because it does nothing (I can see) to speed up air flow through the venturi. In fact I would suss it to slow down air movement. If there was a enormous and obvious advantage it would come from increased turbulence or something else equally hit or miss.
But hey, prove me wrong :-\.
« Reply #3 on: August 12, 2010, 03:03:59 pm »
There was an almost identical gizmo produced by Skunk Works back in the early seventies. It worked in conjunction with their vortex inlet manifold of which I have fitted to my RT1 engine. Methinks it's a load of shit but I'd be prepared to give it a shot if someone bought me one.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #4 on: August 12, 2010, 03:12:21 pm »
I don't know if this gizmo works, but I know for a fact that these work.
http://www.thunderproducts.com/u_f_o.htm
Been using them for over five years with excellent results.
Offline Mike52
  • 81 KTM 125 LC
« Reply #5 on: August 12, 2010, 03:22:40 pm »
Another intelligent observation MX.
 All those bike makers were so Dumb that they missed this free HP boost.
« Reply #6 on: August 12, 2010, 03:26:45 pm »
Offline Mike52
  • 81 KTM 125 LC
« Reply #7 on: August 12, 2010, 03:30:30 pm »
I know one gizmo that definitely works.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=160372062329&ssPageName=STRK:MEWNX:IT#ht_3604wt_1059
They put them on those little pocket bikes Firko, can you imagine? :o :o
« Reply #8 on: August 12, 2010, 05:06:38 pm »
I haven't tried them but have been thinking of it (or D.I.Y.).
I would suss to actually work because see why in principle that they work - improved, smoothed, air flow through the venturi.
Offline VMX60
« Reply #9 on: August 12, 2010, 05:11:56 pm »
Cappra
Most people laugh at the UFO once you have the jetting sorted which can take a while there a good unit
Brought my first one over 8 years ago
I am a believer
« Reply #10 on: August 12, 2010, 05:39:27 pm »
I can understand the theory behind the powernow, by using a blade that comes as far forward as the slide it possibly fools the carb into acting as though it is smaller diameter. No idea if it actually works
« Reply #11 on: August 12, 2010, 06:33:32 pm »
That what the slide does  ;).
The only way that the Powernow will improve power is if the 'channeled' air speeds up or smooths the air flow to such a degree that it improves efficiency of the venturi to more accurately mix the air/fuel or if in some way it improves atomising of the fuel. And the effect would have to be dramatic to have a noticeable effect to power.
The only way there is going to be more power is by more air/fuel been feed to the engine, or, what air is been feed in is more efficient by means of atomizing.
The other contradiction that has more BS metre atingling is the improved top end performance.
I'm not saying it doesn't - they are offering dyno sheets - but there's no stand out reason as a basis of their claims. I'm a 'doubting Thomas' waiting for someone to whack me between the eyes with the bleeting obvious.
Offline Mike52
  • 81 KTM 125 LC
« Reply #12 on: August 12, 2010, 06:42:01 pm »
Sorta like that Aluminium whirley thingy advertised on telly.
Saves you fuel AND gives you more HP.
Whatever you do never let the maths get in the road of a good scam.
As for the twirley bit mixing the fuel better I thought the angle built into the inlet port did exactly that.
From the factory no less. :o
And what about the spark booster thing that used to be sold at the shows.
Cost about $80 but never open one or you will be real pissed.
By putting a gap in the spark lead you can increase the spark voltage.
So you paid $80 for a gap. :o
« Last Edit: August 12, 2010, 06:45:22 pm by Mike52 »
Offline sudman
« Reply #13 on: August 12, 2010, 07:38:40 pm »
I had a Gasgas 200 with one on it when I purchased the bike, tried it with & without as far as I could tell it did nothink at all. ;D
Offline Toolboy
« Reply #14 on: August 13, 2010, 11:52:52 am »
I had the powernow fitted in my 07 RM250 and it defiently made a difference to the mid range, i also had to go leaner in the jetting.
I would like to try on my 79 RM400
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
