Author Topic: Fibre washer material  (Read 4183 times)
« on: August 10, 2010, 07:18:37 pm »
Does anyone know what the proper name for the material used that those red/brown fiber washers are made from? I want some of the same material but in sheet form around 1-2mm thick. i know its available but im not sure what exactly to look/ask for.
Re: Fibre washer material
« Reply #1 on: August 10, 2010, 07:34:29 pm »
  "Sealrite"      comes to mind.
« Reply #2 on: August 10, 2010, 08:18:04 pm »
This sort of material
« Last Edit: August 10, 2010, 08:19:58 pm by LWC82PE »
Offline Stan S
  • Ballarat Victoria
« Reply #4 on: August 10, 2010, 08:36:12 pm »
So its called Vulcanized Fibre? It seems to be what im after so i might give them a try but it would be good to get it locally. Thanks
Offline Stan S
  • Ballarat Victoria
« Reply #5 on: August 10, 2010, 09:00:00 pm »
I have a feeling that electrical wholesalers may sell Vulcanised fibre sheet for insulation.
Or maybe this company have thicker sheet than this thats listed on their website.
It might be a start anyhow.
AKC's Australian Knifemaking Supplies
Tel: 08 9572 7255   Fax: 08 9572 7266
PO Box 149  CHIDLOW  6556   WESTERN AUSTRALIA
[email protected]
Spacers:  Vulcanised fibre material used for cushioning between tang and grip slabs or scales.
Also used for decorative purposes to add contract .. 0.1 x 12.5 x 25-cm   Only $5.50 per sheet
    * M1900    Satin Grey
    * M1901    Pitch Black
    * M1903    Pure White
    * M1904    Bright Red
    * M1908    Brick Red
    * M1931    Royal Blue
    * M1932   Canary Yellow
    * M1934   Kelly Green
Fibre Spacers
Offline suzuki 400
« Reply #6 on: August 10, 2010, 11:12:30 pm »
try plumbers shops also may have a source
Offline PEZBerq
  • Brisbane
« Reply #7 on: August 11, 2010, 10:02:38 am »
Super Cheap and Repco sell little packets of assorted washers in that brown stuff.
« Reply #8 on: August 11, 2010, 12:44:47 pm »
Im NOT after washers though. I want the same material but in a sheet form, electrical grade i think is what i need?. A piece something like 300x 300 would be plenty. I did ring a plumbing shop but they were absolutly useless and did not have a clue and said its not the sort of thing they have. That probably rules that out.
