Author Topic: 1983 CR 500 rear brake  (Read 3170 times)
Offline HL400
« on: August 10, 2010, 05:56:27 pm »
Hi Husky experts, does any one no of a splined rear brake cam and lever that will fit a CR500 backing plate as the standard one only has a single flat on the cam, so there is very little adjustment. also a alloy brake lever would be nice as well.  HL
Offline PEZBerq
  • Brisbane
Re: 1983 CR 500 rear brake
« Reply #1 on: August 10, 2010, 06:56:11 pm »
Hmmm....there should be heaps of adjustment available on the brake rod.  You shouldn't have to move the brake arm on the shaft.  Are your brake shoes worn badly? If so replacements are plentiful.  Cheers
Offline HL400
« Reply #2 on: August 10, 2010, 07:33:49 pm »
I have just put in new shoes and to get the adjustment right I have to have the the nut wound right up. !!!!  HL
Offline PEZBerq
  • Brisbane
« Reply #3 on: August 11, 2010, 10:00:17 am »
Strange.  Can you post a photo of the setup of the rear brake plate. Are you using the original brake rod and stay rod? You should also be able to adjust the position of the rear brake pedal.  Maybe you have it set way too high? That would mean the brake rod would need to be screwed right up as you describe. Just guessing!
Offline HL400
« Reply #4 on: August 12, 2010, 04:37:57 pm »
Thanks for that I will post a pic as soon as I get it back togeather HL
Offline VMX60
« Reply #5 on: August 12, 2010, 04:52:38 pm »
Some of the EBC  new brake shoes are the wrong size on many Husky models had this same problem on a early 400
