Marketplace
Wanted
Desperate for head gasket
Topic: Desperate for head gasket (Read 1884 times)
pirie593
A-Grade
August 10, 2010, 02:33:02 pm »
I need a head-gasket (one that doesn't blow out within 5 minutes of use in a supposedly re-built engine) URGENTLY for a 1982 Honda CR480. If any-one can help with a source, greatly appreciated.
TT
Re: Desperate for head gasket
August 10, 2010, 02:58:30 pm »
Hey Pirie,
These 3 dealers all
claim
to have one on their shelves................
Toowoomba M/Cs 07 4632 2955
Peter Stevens 03 5221 0400
Clem Nunn 08 9459 5544
Good luck!
pirie593
A-Grade
August 10, 2010, 07:23:43 pm »
Thanks Tony
Big John
C-Grade
August 10, 2010, 08:07:10 pm »
I had a mate with an IT465, we couldn't keep head gaskets in it. The only way to get around the problem was to put 2 base gaskets in it to try to reduce the compretion ratio, it seemed to work.
LWC82PE
Superstar
Reply #4 on:
August 10, 2010, 08:59:04 pm »
I reckon the problem could be distorted head surface/barrel surface. i know someone with a PE400 that had to get his studs removed and then have the 2 surfaces machined parallel. Also i would also recommend coating the gasket in this which is good for head gaskets.
you can also get it in a spray can
Last Edit: August 10, 2010, 09:12:31 pm by LWC82PE
pirie593
A-Grade
Reply #5 on:
August 10, 2010, 09:11:44 pm »
Got one...many thanks to all
Marketplace
Wanted
