Author Topic: xr200r problem  (Read 4380 times)
Offline suzuki447
xr200r problem
« on: August 10, 2010, 10:47:28 am »
hey guys got little problem with mates bike seems to be oil,n plugs we set carb back to standard settings in manual ,good fuel, very hard to start after while ,if u put new plug in it starts first kick and run great but after awhile,its hard starting again ,any ideas bike is in great condion  ,motor strong with no problems beside this,any help would b good thanks don
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: xr200r problem
« Reply #1 on: August 10, 2010, 10:51:56 am »
Is it a mid-80's RFVC four valve model?
If it is you probably have a cracked head between the plug and one of the valves (a common problem with mid-80's models)
Ban BLACK rims NOW
Offline suzuki447
Re: xr200r problem
« Reply #2 on: August 12, 2010, 09:59:18 am »
no its 81 2valve thanks don
Offline smed
Re: xr200r problem
« Reply #3 on: August 12, 2010, 01:27:52 pm »
the slide needle & needle jet could be worn,common problem with four stroke hondas with kiehin carb,makes them run rich & foul plugs,if thats the problem it cant be tuned out the only fix is a new needle & jet,I figure you are no dummy seeing the number of bikes you have so I,m assuming you have checked valve clearances & air filter cheers Smed
Re: xr200r problem
« Reply #4 on: August 12, 2010, 11:40:13 pm »
as smed says and check the float tang where the needle makes contact they wear badly there as well causing incorrect float level
Offline matcho mick
    • Moto Tumbi
Re: xr200r problem
« Reply #5 on: August 13, 2010, 01:29:11 am »
plug cap?,big resistance when up to running temp?? :P
Offline Mike52
  • 81 KTM 125 LC
Re: xr200r problem
« Reply #6 on: August 13, 2010, 03:38:51 am »
Valve guide seals? :)
Offline suzuki447
Re: xr200r problem
« Reply #7 on: August 15, 2010, 09:00:39 pm »
thanks guys ,bike is a mates so i help him chek everything u  suggested ,i have 84 4valve 200 which i have just rebuilt with help of a thumper expert ,i,m a 2stroke boy so i know bugger all about thumpers,thanks again.
