Author Topic: Need help.not vmx but 89 kx125  (Read 2017 times)
cagiva125
« on: August 08, 2010, 06:32:10 pm »
Hi i brought a kx 125 the other day was told had rebuilt motor(ha)they all say that,but starts first kick but when started revs at full throttle and wont back off, i pulled the carb apart but looks ok,does have a small hole in bottom of carb where the breather has rubbed through,throttle does work springs back etc not sure what else it could be????????thanks
Offline Mike52
  • 81 KTM 125 LC
Re: Need help.not vmx but 89 kx125
« Reply #1 on: August 08, 2010, 06:47:13 pm »
Dumb question but the slide is in the right way??
Just a thought. :)
« Reply #2 on: August 08, 2010, 07:33:32 pm »
Pull the carb out, with the cable attached, and make sure the slide is actually closing.
Where is the hole? If it allows air into the motor when the throttle is shut, then it will be your problem. One of the many 'expoxy putty' products (Knead It, Metal Mend, etc) should be able to make a decent repair - but make sure the surface is spotless, and make sure that if the repair does fail that it won't suck the stuff into your motor...
cagiva125
« Reply #3 on: August 08, 2010, 07:53:22 pm »
Hi guys thanks will check tomorrow,sounds definatly like carb problem,id sayive done something wrong!!!thanks again!
cagiva125
« Reply #4 on: August 08, 2010, 11:08:28 pm »
Why didnt i look,the slide wasnt closing all the way,i checked everything else,thanks guys!!!!!!!!!!!!!!!!!!!!!!!!! now running great!!
