Author Topic: twin shock yamaha rear sprocket 46-48 tooth 520 6 hole  (Read 1287 times)
« on: July 29, 2010, 10:44:38 pm »
wanted rear sprocket 46-48 tooth for my yz125 dirttrack bike.
all rt 360
all dt250s
all dt360s
all mx 250/360
as long as it is 520 chain and 6 hole it will fit
jim
Re: twin shock yamaha rear sprocket 46-48 tooth 520 6 hole
« Reply #1 on: August 01, 2010, 12:03:12 am »
any one !!!!!
need asap for testing my yz125
« Reply #2 on: August 02, 2010, 06:46:25 pm »
new or used......  i can send a steel one off one of my Dt's if your desperate.
« Reply #3 on: August 02, 2010, 07:38:31 pm »
freaky
if you have 1 that would be great steel is ok
jim
« Reply #4 on: August 02, 2010, 09:52:00 pm »
8mm bolt, 60 bore size and 40mm between holes x6, think i have a used 47 you can try.
 Same as Xt250G/H and so on
