Author Topic: 1977/78 DT250  (Read 5316 times)
Offline jimson
  • Sanctuary point N.S.W
1977/78 DT250
« on: July 28, 2010, 10:41:29 pm »
G'day viewers I have been offered a 1977/78 DT250. Would this be okay for vinduro or to heavy and gutless ?  :-\  I have the early DT250 twin shock model and they look good but the pic's I've seen of the 77 model the bike looks lumpy I haven't seen the bike yet  ::) so before I go ahead whats the go on the 77 model. jimson
Re: 1977/78 DT250
« Reply #1 on: July 28, 2010, 10:49:28 pm »
They're very heavy, but a lot of the weight is easy to get rid of.
Not a sexy bike, but they've got more suspension than the twin shock models and are still DT reliable.
Offline jimson
Re: 1977/78 DT250
« Reply #2 on: July 28, 2010, 10:56:48 pm »
Nathan would a plastic tank off the same year YZ fit same with gaurds .jimson
Offline crossedup2
  • Never enough shed time.....
Re: 1977/78 DT250
« Reply #3 on: July 28, 2010, 11:28:37 pm »
Hi Jimson
Not sure about plastic tank. You can put in the YZ or IT gear set! Most of the internals are interchangable with the racer models. Clutch cover is different (Autolube) but again YZ or IT fit.
You could put some better forks and triple clamp. Loose some weight around the bike. Put some good tires on it and have fun.
They are plain reliable and with some simple bits removed, changed or added, just as much fun as that DT1!
Peter B
dave
Re: 1977/78 DT250
« Reply #4 on: July 29, 2010, 07:34:16 am »
Once you go to the expense of plastic tanks and suspension upgrades, you'd might as well look around for a IT250F/G or a PE250N/T. Just keep it as it is, DT250! They're good softcore trailbikes!
Offline jimson
Re: 1977/78 DT250
« Reply #5 on: July 31, 2010, 11:05:52 pm »
Well I've pushed the rust bucket up the side of the house and walked away.  :'(  Why do I buy this sh#t for  :-[  could someone tell me if this 77 DT250 is points or CDI and if it is CDI should it be a straight swapover to a DT1 250 I can't look at it until I think its got something I want need. jimson
Offline big mac
Re: 1977/78 DT250
« Reply #6 on: August 01, 2010, 07:41:52 am »
Should be a cdi unit dont know about the swap for earlyer model.
Re: 1977/78 DT250
« Reply #7 on: August 01, 2010, 09:42:54 am »
I've never gotten my head around which of the monoshock DT250s had CDIs and which had points - AFAIK, you've just gotta check.
If its a CDI one, then it will go straight into your DT1.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 1977/78 DT250
« Reply #8 on: August 01, 2010, 11:39:29 am »
yes indeediedoo Jimson, and say goodbye to "kickback" from that nasty DT1 kick lever forever....... ;)
you'll just need a few zip ties and some creative placing for the CDI box.
"flat bickie"
Offline jimson
Re: 1977/78 DT250
« Reply #9 on: August 01, 2010, 08:45:07 pm »
Its got points  >:( no CDI  the frame is rusted beyond repair but it has a full wire loom and the front forks might be okay the carbie looks small for a 250 and the front wheel is round instead off square like the back so I've got spares for the money I spent  :-\  jimson
Re: 1977/78 DT250
« Reply #10 on: August 01, 2010, 10:04:39 pm »
Because it allways seems like a good idea at the time.
I had a 77 400 that I bought new. It was a horrible dog of a thing, it was one bike I always considered a lemon.
The 77 400 was the first of the monoshocks and mine had CDI, I would have thought the 250 would have had CDI as well, maybe someone fitted it up with an old system sometime in its life.
