Author Topic: BMCC at Harrisville  (Read 2489 times)
Offline popeye
BMCC at Harrisville
« on: July 28, 2010, 05:33:42 pm »
Due to the rain today myself and Nick Higgs had the day off. So we went out to the Harrisville track and had a look, it is going to be a great track to ride on so all you classic MX nuts if you miss this event you will kick yourself afterwards. The track is 2.1 Klms long clock wise direction with a good mixture of top gear flat out and some nice technical stuff. I think it will suit all the classes well, sidecars included, the jumps can be riden over or get some air.. There will be camping the night before and will be a track set up Sat arvo..... Also the owner of the property is going to have a bon fire so lots of stories to be told..... Any way hope to see you there........
Offline mudguard
Re: BMCC at Harrisville
« Reply #1 on: July 28, 2010, 06:01:10 pm »
  Sounds like a great track. What date is this event on?   :)
Offline popeye
« Reply #2 on: July 29, 2010, 02:08:11 am »
The event is on the 15th August, the track is on private property about half way between Peaks Crossing and Harrisville, l will put signs out on Saturday to point you in the right direction, should be a blast, lm also going to organise a trail ride to get there for anyone interested........ The trail ride will start from Greenbank area about 830-900am...... Registered bikes only....... Any size.
STW996
« Reply #3 on: July 29, 2010, 05:46:08 am »
Nice work Popeye. Arm maybe out of action but great to see you out and about
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #4 on: July 29, 2010, 08:09:44 am »
i've been hearing good things about this one ever since it began.
looking forward to it for sure!
how long is the straight? would it be longer than Nudgee?
gearing check...
"flat bickie"
Offline popeye
« Reply #5 on: July 29, 2010, 07:55:05 pm »
Maybe a touch longer Mick and you come onto it a little faster.. Also about a 100 metre long slight up hill start should be good....... Had CT Scan on the liver and kidneys today and all coming along good so, as long as the shoulder is ok l might have a slow ride on the 15th........ Heres hopin....
