Author Topic: Instant gasket on reed block  (Read 5552 times)
Offline utsman
« on: January 02, 2008, 10:50:43 am »
So here's is the story,
I pulled my cr500 down partly to have a look at the reeds etc. Anyway all looks good but of course te reed block gasket is stuffed. I ordered a new one two weeks ago from Honda and it's gonna be at least another week.NOOOOO. I want to ride these holidays.Usually parts like that only take a few days.
Can I get one from anywhere else or has anyone ever used instant gasket there. I know it will seal but I don't like the idea. Usually when you tighten the bolts the stuff squishes out and I don't want bits breaking off and getting sucked into the motor.
ANY ideas.
UTSMAN
Offline paul
Re: Instant gasket on reed block
« Reply #1 on: January 02, 2008, 10:59:37 am »
make one outa a corn flake box  it easy  or gaskit paper
090
« Reply #2 on: January 02, 2008, 11:02:46 am »
What part of town you in mate?
Offline utsman
« Reply #3 on: January 02, 2008, 11:16:29 am »
Hey Guys,
Paul - is it HArd to get exact?
090 - I live in east Brisbane
UTSMAN
090
« Reply #4 on: January 02, 2008, 11:28:26 am »
Call me 0417192302.
Cheers, Brad
« Reply #5 on: January 02, 2008, 12:04:40 pm »
You could also go to the nearest Super cheap (they are always just around the corner where ever you live) and grab some gasket paper it works a treat.
It's a sheet of cardboard like material that's designed to be used as a gasket, just cut out the rough size you need, place it against the surface you need to seal and gently tap with a hammer, this will leave an indentation on the paper which you cut out to give you the perfect gasket. I use it all the time for that kind of thing and it's as cheap as chips.
« Reply #6 on: January 02, 2008, 12:07:22 pm »
Oops! just read all the postings,looks like you already know about the gasket paper.
Back to my hole.
Offline utsman
« Reply #7 on: January 04, 2008, 09:22:50 pm »
Thanks Guys,
It's all good. 090 sorted me out with a new gasket. Who would of thought the gasket from an 84 model would fit the 93, but hey, it does.
Thanks again 090
later
Doc
« Reply #8 on: January 09, 2008, 08:25:59 am »
I'm with evo..I make all my gaskets excepting the head gasket and this I'd be making also if I had a selection of copper sheet. What I like about making base and top end gaskets is you can make them a much better match to port openings and such..better than they do at the factory anyway ;)
