Author Topic: 85 CR250 water pump repairs  (Read 4282 times)
Offline ideasman
  • father of two bike loving boys
« on: July 23, 2010, 09:24:29 pm »
Rebuilding an 85 CR, has the standard corrosion issues (rather severe) in the magnesium casing, I have repaired this type of pitting with success in the past, however someone has had a go at this in the past with something that looks like superglue and sand. My question is how to best remove the remnants of the old muck. I am considering sandblasting, has anybody any experience with this and the magnesium casing?
any and all experience appreciated.  Cheers
1985 XR80,1986 XR100,1986 RM80, 1984 YMF350, 1997 KTM400,1996 RM80, 2007 TTR90E, 1987 PW50.
Re: 85 CR250 water pump repairs
« Reply #1 on: July 23, 2010, 09:57:05 pm »
Yamaha magnesium brake plates and clutch covers will bead blast just fine.
Most epoxies are quite hard but not very tough, meaning that the bead-blaster will make fairly short work of them.
My gut feeling is that it will be fine.
« Reply #2 on: July 24, 2010, 12:11:41 am »
I took the easy way out with my 83 and sent it to Geoff Morris who removed the old playdoh and repaired the case and pump area etc?
Rossco
Offline ideasman
« Reply #3 on: July 24, 2010, 07:29:50 am »
Hey Rosco, how do i get in contact will Geof Morris, and what sort of dollars would i be looking at.
« Reply #4 on: July 24, 2010, 08:11:33 am »
Geoff Morris is a forum member here look for "GMC" in the members section and shoot him a PM or Email. he also advertises in VMX Mag.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #5 on: July 24, 2010, 09:48:54 am »
sometimes the "poopy" glue stuff can be quite hard as Nathan said.
if you're able to use the die grinder first to remove the bulk of it, that'd make for less impact on the cases with the blaster. ;)
"flat bickie"
« Reply #6 on: July 24, 2010, 01:45:17 pm »
I have repaired this type of cover before, You need to use alloy bur and get back to the parent material then you tig weld with Mag rods, you can build the case back to newish useing this meathod.
« Reply #7 on: July 24, 2010, 05:12:55 pm »
watch out for warping when welding though?
Offline smed
« Reply #8 on: July 24, 2010, 07:49:46 pm »
I have the same problem with an 85 cr125,whilst searching for a good cover thats repairable cause mine is too far gone I came across a thread on thumpertalk,saying that the clutch cover from 89 will fit all cr250,s back to 85 & they are ally not mag,they may also have the 2 part cover for quick clutch access,I cannot verify if this is true or not but it might be worth looking into,also they may not look the same so if you were doing a correct resto no good but for a ride/race bike it would solve the problem for good,88 & 87 may also have the ally cover,once again you would have to research that,now if only the gods of 85 cr125 clutch covers would smile upon me i,d be a happy little vmx,er
« Reply #9 on: July 24, 2010, 08:44:14 pm »
Mag covers dont warp much as they need such low heat to weld 10 to 15 amp's in most cases, you just dont put much heat into them, still clamp them to a flat surface
