Author Topic: PE400 vs RM400 seat base  (Read 2969 times)
rohan
« on: July 23, 2010, 06:17:18 pm »
Can anyone tell me:
Is the PE400 and RM400 seat base the same? Therefore will the RM seat base fit on my PE without modification? Along with that will a new RM foam fit on my PE base?
Offline frostype400
Re: PE400 vs RM400 seat base
« Reply #1 on: July 23, 2010, 06:22:43 pm »
I think they are different I think vintage suzuki or dc plastics sell pe foam and seatcover a base isn't to hard to come by ebay.com the 250txz is the same as the 400. :)
1971 tm400 and PE's
rohan
« Reply #2 on: July 23, 2010, 06:36:18 pm »
Do you know if the bases are the same ie the 250TXZ is the same as the PE400 which is the same as the RM400?
« Reply #3 on: July 23, 2010, 07:05:44 pm »
Seat bases  PE 250 /400 T-X *  will interchange  with    RM 250 /400T *                 * note rear mount brackets are different -  can be an easy fix if you are changng seat cover.
« Last Edit: July 23, 2010, 08:15:32 pm by oldfart »
Offline frostype400
« Reply #4 on: July 23, 2010, 07:50:28 pm »
the pe 250txz is the same as pe 400 identical as are the frames bar numbers and comp. plate.
1971 tm400 and PE's
« Reply #5 on: July 23, 2010, 09:23:21 pm »
Part # = 45100-40600-48F
Part Description = SEAT ASSEMBLY
Model Count = 6
PE250T 1980
PE250X 1981
PE250Z 1982
PE400T 1980
PE400X 1981
PE400Z 1982
To use RM400/250 seat you will need the RM fuel tank too. I reckon all you need to do is pop rivet the brackets in different spots on the base. In all the original RM250/400 photos ive seen, the RM, seat foam looks a different shape to the PE. The RM foam looks lower and narrower at the front and the PE foam is more of a square block.
Basically if your missing a seat and trying to find a 400 seat and wondering if RM is the same, well its not, just stick to looking for a PE250/400 seat which would be easier to find than a 79/80 RM seat anyway.
