Author Topic: '86 CR250 chain guide  (Read 11589 times)
Offline Paddles
« on: July 23, 2010, 12:36:10 pm »
good afternoon red heads, does anyone know where i can purchase the wear block that goes inside the rear chain guide of a 1986 CR250? honda has them listed as unavailable. i was going to try and make one out of a block of nylon, but if you guys know of any aftermarket manufacturers of these i'll just buy one. thanx, john.
Offline Mike52
  • 81 KTM 125 LC
Re: '86 CR250 chain guide
« Reply #1 on: July 23, 2010, 12:52:10 pm »
That,s not the one you want on ebay at the moment[ under vmx]. :)
« Reply #2 on: July 23, 2010, 01:01:26 pm »
Try Forum Member E74. Red Devil racing
Nice model the CR250RG i have 2 of them.
Offline Paddles
« Reply #3 on: July 23, 2010, 03:36:13 pm »
yeah mike, that's exactly what i'm after or more to the point i'm after the little bit inside that the chain slides on. i saw that one but was going to see if i could source one local and new because i just don't know what the one on ebay would be like.
thanx for the tip hoony i'll have a look at what RDR have got.
as a side issue hoony, do you still use the original pegs on your cr's? or have you replaced them with something? what wide pegs from other models will bolt straight up?
« Reply #4 on: July 23, 2010, 03:44:59 pm »
i have modified my original pegs with GMC Footpeg wideners, not sure if any later model stuff bolts straight on or not.
Offline whitey 43
« Reply #5 on: July 23, 2010, 07:15:10 pm »
I am looking for wider pegs for the 125 I just bought...Done the research,'87 different part #,'88 different again,'89 different again. Could just be the colour of the paint.Im going to buy a set of '88 off ebay & see how they go...
« Reply #6 on: July 23, 2010, 08:37:45 pm »
is your bike a CR125RG whitey?
let us know the outcome then.
090
« Reply #7 on: July 23, 2010, 10:26:01 pm »
Offline Paddles
« Reply #8 on: July 25, 2010, 06:51:21 pm »
thanx guys, i ended up just cutting the little bridge part at the bottom of the outer guide away and bolting in a piece of nylon for the chain to run on using the existing lower bolt holes. i might have a look at buying some wideners for the pegs then if that's easiest.
hey hoony, i haven't had this bike long and i'm trying to set it up so given you've got a couple of them i might fire a few questions your way from time to time.
Offline whitey 43
« Reply #9 on: July 30, 2010, 04:44:29 pm »
Yeah Hoony, its an '86 model...Bought it off evilbay last week,its got A worn out chain guide too! I just ordered A set of 43mm cartridge showas for the front.Also got A genuine Pro Circuit Cylinder & pipe coming
from U.S. Hope I have the ability to ride it!
« Reply #10 on: July 30, 2010, 05:31:22 pm »
hey Hoony, i haven't had this bike long and i'm trying to set it up so given you've got a couple of them i might fire a few questions your way from time to time.
No worries Email or PM me when you need to.
great stuff, i will Never sell my #1 bike as it have had it since 1987 it will become like Firko's squarey 350 Maico.
Pro circuit pipe is the goods, cylinder will work well too, they are very fast bikes, but not peaky, just good strong engines.
best tip i can give you is retire the Standard Showa shock and get a white power or Ohlins for them
« Last Edit: July 30, 2010, 05:33:39 pm by Hoony »
Offline whitey 43
« Reply #11 on: July 31, 2010, 09:21:12 am »
Im looking for one as we speak...also for A wp shock for my '88yz250. any ideas?
« Reply #12 on: July 31, 2010, 09:54:49 am »
Didn't '86 models already have 43mm cartridge forks ???
Offline E74
« Reply #13 on: July 31, 2010, 10:28:20 am »
Keep an eye on this guy. He seems to be pumping out a fair bit of this type of stuff. Also inlet manifolds.
http://cgi.ebay.com/ebaymotors/81-82-83-84-85-86-CR125-250-480-500-AIRBOX-TUBE-DRAIN-/270594621713?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item3f00b24111
RDR Have just become the Australian Agent for these guys, (Formtech Industries) , we should have our first order landing next week, from there we will gauge the requirements and try to stock at least one of everything they manufacture for Honda's 73-89
Wotto29
« Reply #14 on: July 31, 2010, 10:38:13 am »
        GOOD to know RDR will be stocking parts
        for PRE 90 Honda CR's.
         At least someone cares!!!!
