Author Topic: Spark Plug for 1990 ktm 500 cc, 2-stroke  (Read 10476 times)
Offline jurado
« on: July 21, 2010, 10:17:46 pm »
Hi,
I have just restores a 1990 ktm 500 cc, 2-stroke, water-cooled. I have read somewhere that the recommended spark plug is the NGK B8 EGV, which is very much expensive than the B8 EG. I am not using the bike for competition, and just for some fun rides from time to time. Any problem / difference if I stall the B8 EG?.
Thanks. Jurado.
Offline frostype400
Re: Spark Plug for 1990 ktm 500 cc, 2-stroke
« Reply #1 on: July 21, 2010, 11:27:11 pm »
Hi jurado, go the eg it isn't going to hurt but 8 is a fairly hot plug you may find it runs better how you ride on a eg9 or 10 slighty cooler plugs but you never buy just one plug you want to buy atleast three incase if the first goes you have 2 spares if the second goes you have a problem wrong heat range dirty filter or alike. I would buy the eg8 and see how you go thanks Michael.
1971 tm400 and PE's
« Reply #2 on: July 22, 2010, 09:04:47 am »
Stick with the 8 series heat range, a B8EG will be fine, just don't use a std ES series, they are very unreliable in my experience. The "V" stands for the v shaped groove in the electrode and is the only difference in the two.
Offline jurado
« Reply #3 on: July 22, 2010, 03:49:09 pm »
Thanks for the advise.
Regards, Jurado.
http://i28.tinypic.com/211kwsl.jpg
Offline jurado
« Reply #4 on: July 22, 2010, 03:50:48 pm »
Offline jurado
« Reply #5 on: July 22, 2010, 05:18:34 pm »
My question about the right spark plug is because a sense some sudden engine detonations when I close gas. I run the bike in a normal regime, but when I close gas, in most cases I notice one or two engine detonations. And this might be due to a wrong spark plug. Not sure. The bike seems to run and accelerate ok in all the ranges, including idling range.
The bike has a new carb, one keihin 39 pwk. They told me they jetted appropriately for my bike as per KTM advice, and installed a 55 slow jet, 175 main jet, and a ceg needle. Air mixture control screw is 1,5 turns open.
It is rather hot here in Spain (summer time). Not sure if this might also influence.
Any advise welcome.
Regards, Jurado.
« Reply #6 on: July 22, 2010, 05:20:57 pm »
you can use the even cheaper 8-ES if you like
« Reply #7 on: July 22, 2010, 10:49:48 pm »
Hola Jurado
La condición se causa cerca a mucho aire o a no bastante combustible con la válvula reguladora cerrada. Aumente el tamaño del jet lento a 60. Tengo un proyecto para poner uno de esos motores en un marco de Aprilia RS 125
« Reply #8 on: July 22, 2010, 10:58:26 pm »
Hola Jurado
The condition is caused by to much air or not enough fuel with the throttle closed. Increase the size of the slow jet to 60. I have a project to put one of those engines in a framework of Aprilia RS 125
Offline TeeBone
« Reply #9 on: July 23, 2010, 02:47:50 am »
Thanks MICK-DE for the translation - Lozza is a cunning linguist for sure! :o
« Reply #10 on: July 23, 2010, 01:24:26 pm »
Google translation, my Spanish extended only to sourcing a bed for the night, directions to the train station,cost of a beer and anything to do with senorita's. I was amazed how far my trusty Lonely Planet book took me but as they say that is another story ;D
Offline jurado
« Reply #11 on: July 28, 2010, 03:47:41 pm »
Thanks for the advise. Actually, the slow jet the carb has was a 52. I have a spare 55 jet and I´ll try with this one and let you know.
Regards,... Jurado.
Offline Mike52
  • 81 KTM 125 LC
« Reply #12 on: July 28, 2010, 07:03:09 pm »
Hi Jurado
Was looking at the photo of your KTM and noticed that it looked almost the same as my old 1986 250. :)
What do you think?
Exhaust a bit different and rear master cyl is in a different spot but the rest looks much the same. :)
« Last Edit: July 28, 2010, 07:05:40 pm by Mike52 »
Offline jurado
« Reply #13 on: July 28, 2010, 10:21:28 pm »
Yes, I guess most of frame, plastics, shock, front fork, etc is the same. Probably also ignition system. I have the SEM K10 ignition. Obiously, motor, pipe, etc would be different.
Regards,
