Author Topic: Hybrid Suzuki 125/175 engine?  (Read 6417 times)
Offline oldmxracer
« on: July 21, 2010, 12:41:40 am »
Just about have my project "RM175" chassis done and will soon start putting the engine together. I mocked the 175 engine up and modded a pipe to fit so far.
Original plan was to use the 175Z engine with a 185 piston and the 125T transmission and the 175 big end needs overhauled. Just wondering what some other options might be now that I know so many pasrt need replaced.......
monaro308
Re: Hybrid Suzuki 125/175 engine?
« Reply #1 on: July 21, 2010, 01:19:54 am »
Where are the pics??????
Offline oldmxracer
« Reply #2 on: July 21, 2010, 02:25:53 am »
I'll snap one for you tomorrow hopefully. Just a semi-nice 125T roller for now. Only "trick" thing done so far was splicing the 125 stinger to the 175 pipe.
« Reply #3 on: July 21, 2010, 08:50:29 am »
TS 185 rod kits are the same as 175.
monaro308
« Reply #5 on: July 21, 2010, 02:16:20 pm »
Cyclegod...you are a master at this.
You should be renamed to ebaygod ;D ;D
All i ever find is rods only or pins only.
At that price who could argue and i might have put one away for a rainy day.
cheers....mario
trailietrash
« Reply #6 on: July 21, 2010, 05:52:42 pm »
Damm good price for that rod kit. I just paid a bit over Au$100 for the same brand for my TS 125 A crank rebuild at the repairers.
Offline oldmxracer
« Reply #7 on: July 22, 2010, 09:49:31 am »
Here's the FrankenBike project. Still need seatcover, tires, ect.
monaro308
« Reply #8 on: July 22, 2010, 10:06:10 am »
Have you checked if the c/shaft sprocket lines up with the rear sprocket?
My 83 PE engine sat about 5-10mm too far to the left and i had to move the engine over in the 84 RM frame.....check my RM175 franken post.
Keep posting pics ;)
Cheers...Mario
Offline BAHNZY
« Reply #9 on: July 22, 2010, 10:47:19 pm »
Went down much the same track with a later model PE. Awesome bike to ride.
Rod (BAHNZY) Bahn
Offline oldmxracer
« Reply #10 on: July 23, 2010, 07:06:48 am »
Oh I went over your thread about that 175 with a fine tooth comb Bahnsy. Here's my 82 do-it-all-rider.
Offline DR500
« Reply #11 on: July 25, 2010, 11:02:54 am »
I have brought one of the rod kits for my PE 175 from the same company and all good except no thrust washers,which are still available from Suzuki,Cheers
